Torque Specs
Old Feb 19, 2009 | 11:55 AM
Hashish's Avatar
Default Torque Specs
I was searching the forum and found all the torque specs threads I found were old as dirt and the links within them no longer worked. I need every torque spec and sequence for a 2001 ls1(main caps, rod caps, oil pan, windage tray, heads, intake, exhaust, flywheel, pressure plate, etc.) If anyone knows of a site to find this info at or has a quick reference on a pdf file that would be great. Thanks for the help!
Old Feb 19, 2009 | 05:44 PM
HavATampa's Avatar
A lot of broke links everywhere. Try this old as dirt link out, it's still alive for now so you might want to save it to you rhd while you can.
http://www.ls1howto.com/index.php?category=1
Old Feb 19, 2009 | 09:49 PM
405HP_Z06's Avatar
Street and Performance has a ton of good information on their website. Here's a link to the torque specs they have posted.
http://www.hotrodlane.cc/ONLINETECH/lstorquespecs.pdf
