Oil Pressure problem
Old Feb 1, 2009 | 11:46 AM
Eighty7camarokid's Avatar
Default Oil Pressure problem
OK. So when I was on my way to the auto show yesterday, I was sitting in traffic. Car was idling, in gear, and the oil pressure was about 20-22 psi. When I got moving again, is slowly built back up to 38-40 psi. Now, the car had been running for a good hour and a half at that point. I say this cause when we left the auto show and drove to union station and after we left the hockey game, the pressure stayed at the 38-40 psi no matter if I was cruising or sitting still. Help? Oil pump going bad?
Old Feb 1, 2009 | 11:49 AM
01z's Avatar
01z
changed my oil yesterday and noticed the same thing.
Old Feb 1, 2009 | 11:56 AM
m6speed's Avatar
change your oil pressure sending unit, oil and filter and see if it fixes it, if not then probably bad oil pump.
Old Feb 1, 2009 | 04:42 PM
01z's Avatar
01z
how hard is it to change the sending unit??
Old Feb 1, 2009 | 04:43 PM
Lt1Porsche's Avatar
hard.
Old Feb 1, 2009 | 05:06 PM
LS1Formulation's Avatar
Your car was running for an hour and a half... the oil was hot and thin, making your oil pressure seem low. As soon as it cooled down, the oil got thicker again, making your oil pressure read higher. I doubt there's anything wrong with it.
Old Feb 1, 2009 | 05:28 PM
01z's Avatar
01z
Originally Posted by Lt1Porsche
hard.
like,,,could i do it in the driveway or do i need to pay some ******* to do it?
Old Feb 1, 2009 | 06:32 PM
SOMbitch's Avatar
Like have to pull IM to do it. Easy for some a PIA for others . BTW on the back of the DS head... Get a special plastic socket for it at AA, AZ etc.... It will help. But they usually read 0 or fluctuate real bad when they crap so I dunno........
Old Feb 1, 2009 | 08:41 PM
01z's Avatar
01z
that sounds like a bitch. might as well get a ls6 manifold before i do it. if i have to take if off and put it back might as well. hopefully that fixes it.
Old Feb 1, 2009 | 09:32 PM
m6speed's Avatar
pulling the sending unit is ******* easy.
unhook the wire connected to it, put the special socket on it and take it off, thread in the new one by hand, socket on and screw it on nice and snug, reconnect the wire. done.
Old Feb 19, 2009 | 09:02 PM
The Cook's Avatar
hope im not too late... can't believe no one has said it... but don't the 01-02 f-bodys come stock with the LS6 intake? hope you didn't swap it... cause it did nothing if you did...
Old Feb 19, 2009 | 10:15 PM
GM WORLD CLASS's Avatar
Default it is a problem
my buddys did the same thing. i put a pick up tube and seal in it, still low pressure. i bet money its a pump. how many miles? my 01 z28 has 130k miles and stock pump and NEVER runs less than 40, and i WOT it daily everychance i get. check pressure with a oil pressure tool, if ur gauge is right put a pump in it.
