383 Stroker Machining Question
Old Feb 19, 2009 | 10:00 PM
Rddragon's Avatar
Default 383 Stroker Machining Question
Hi, im in the process of building my ls1 into a 383 stroker. Im using a callies rotating assembly, and i was wondering if anybody knew of any special clearancing involved with this build? Or am i just ok with boring and honeing? Thanks for the help
Old Feb 19, 2009 | 10:07 PM
Steve Bryant's Avatar
LS1 Tech Veteran
GM High Performance did a series of four issues on this very subject about two years ago. Do a search on their web site. Send me a PM if you have questions.
Steve
Old Feb 19, 2009 | 11:35 PM
blackls1ta00's Avatar
yes the the block will need clearanced the rod bolts wont clear,and the windage tray will need washers to clear,ive spent close to a 1k on machining,theres alot involved be prepared.
Old Feb 20, 2009 | 08:11 PM
382ssz28's Avatar
You can do it yourself. You basically have to "mock up" the motor. The pics in the story would help you alot. It's much easier than the old cast iron 406 with big rods. If you don't feel comfortable, take it to a professional and KNOW it's right. If you try yourself, make sure you have .030" between the rods and the block. Save the money from the labor of notching the block and pin the caps, unless you can do that, LOL.
Old Feb 20, 2009 | 08:19 PM
boostnificent's Avatar
here is the article that was suggested above......
http://www.gmhightechperformance.com...1_stroker.html
Old Feb 21, 2009 | 07:59 AM
Rddragon's Avatar
Thanks for the help. I have it at a machine shop right now but they dont work with ls1 383s very often so were trying to find out what to do. thanks for the help guys
