oil on spark plug?
Old Feb 13, 2003 | 01:27 PM
graygmc's Avatar
Default oil on spark plug?
after running nitrous for about 6 months i finally took it off a few months ago. well i just got around to putting back in some tr55's. there were like 2 plugs,#8 and maybe#6, that had some sticky oil on them. i have about 60k right now and only 5k on n20. so what does this mean? are my rings about to give out?should i pull the heads and checked things out?
Old Feb 15, 2003 | 09:29 AM
David Plum's Avatar
Default Re: oil on spark plug?
Possible ring land failure
Old Feb 15, 2003 | 10:00 PM
really slow truck's Avatar
ttt
Old Feb 15, 2003 | 10:25 PM
v8 ute's Avatar
Could be valve guides.
Take out a sprke plug (maybe #8 or #6) and do a leakdown test, if it reads too high your rings arn't sealing.
Or
Take off a valve cover and remove an intake valve spring (with the spark plug out and cylinder full of compressed air) then give the valve stem a wriggle if it moves your guides are most likely stuffed.
Or
Take off your intake and have a look down the intake ports if there is oil pooling around the closed valves most likely your guides are worn out.
Other than that just take your heads off and have a good gander at everything.
Having NO2 on your motor would have placed considerable pressure on your rings and may have caused premature problems also if you had some even slight detonation with this set up you could have broken a ring.
<small>[ February 15, 2003, 10:29 PM: Message edited by: v8 ute ]</small>
Old Feb 16, 2003 | 01:02 AM
graygmc's Avatar
thanks for the reply. so should i just take the heads off and see if everythings ok.and maybe even take them in for a little work.
