Buying 98 ss camaro Ls1 6spd
Check t-tops are tight, and don't leak. Also the steering racks can be problem areas, listen for a clicking noise when turning the wheel back and forth. And the power window motors suck to put it nicely.
Everything I listed is preety much an easy fix, except the tranny and motor.
Rears are cheap for a good used one $300
If your a 1st Gen guy the 4th Gen rears are comparble to the 8.2's IMO.
Not to be confused with the 8.5.
Other than that the 98's are good cars despite what some will tell you, there only down fall is the PCM which is a 1 bar, meaning if your sons intentions are to turbo charge it, he would have to update to a '99 or later computer or get a standalone.
