Too much compression - stroker setup
6 liter iron block Gen III with a stock 4" bore
Stroker crankshaft with a 4.125" stroke
Heads with a 60CC chamber
flat-top pistons
The computation showed 414 CI and a compression ratio at 12.67 to 1
Obviously, this CR is too high for a street car on pump gas although I assume it would kick serious butt on aviation fuel.
Will dished pistons fix this?
My relatives are pilots and they buy high octane avfuel for their planes (102 Octane no lead) ...so why can;t u use this in high compresssion cars ...obviously, it is prohibitively expensive but its more available than race gas...those who have high compression big-blocks that run like **** on low 0ctane unleaded used this trick...my old vette (70 454) did not have the same problem....
...anyway, this is not the point....if a set of Gen iii heads is milled .055 to yield a chamber size of 60cc can you increase the chamber size later to yield 67cc chambers?
...is a dished piston another alternative?
I have read before that avgas is formulated differently and should not be used, let me see if I can find the link.
I have a 418 with a 63cc chamber, .054 head gasket and a -12cc dish. This yields approx. 11.4:1 with the piston .010" out of bore.
Like John stated, you should stick with a larger chamber and you will still need a dish.
If you stick with a 60cc head you should use a 8 cc dished piston. It will get you 11.6:1. This is with a .054" gasket and zero deck. Very good for pump gas and will make great power.
...the 11.6 CR seems really high; are you shure this will run on pump gas. I'm at sea level.
...I assume I can go with a bigger dish ..say 12CC and lower the CR some more...i thought the max would be about 10.75?????
Thanx for the info...
To perform this calculation in CarMath, I added 12cc to the chamber size (72CC [60CC + 12CC] since there is no mathematical perameter for the variable "dished/dommed" piston.
Does this sound correct?
Another question: The 4.125 crank is big; will this fit in a stock LQ4 block (6 liter iron Gen III block)? WIll I need to "clearance the block" for an oversized crank or does this depend on whose crank you use?
I have a 418 motor that is closer to what you are trying to do. If you already have the 60cc heads I would do the following;
6.125" rod
1.0425" compression height
12 cc dish
.054" head gasket
.010" out of bore
This will yield you approx. 11.46:1 No problem with pump gas with the right tuning.
Should make over 500 in both HP and TQ.
