Free Mods
Old Feb 22, 2009 | 08:14 PM
BoostJunkieXL's Avatar
Question Free Mods
Since I'm a relative n00b to all this LSx stuff...Can anyone tell me what the free mods are for these damn cars is? I can't get any of my so-called "buddies" to tell me. Thanks Guys!
Old Feb 22, 2009 | 08:39 PM
jrenfrew0606's Avatar
well you can re rout the cooling lines to were they dont run through your throtle body, and you can also cut the pastic out of the air filtier tray if you take your air filter out you will be able to see what im talking about
Old Feb 22, 2009 | 09:49 PM
Talking
Thanks!
Old Feb 22, 2009 | 10:05 PM
jrpimp00's Avatar
Its a sticky on the board with all the info and write ups
Old Feb 22, 2009 | 10:13 PM
tlee_ls1's Avatar
go to installuniversity.com
Old Feb 22, 2009 | 10:45 PM
blue98Z's Avatar
Beat me to it. Go there they have several write ups.
Old Feb 23, 2009 | 01:37 PM
Zerokube's Avatar
i cant find this sticky anywhere.
Old Feb 23, 2009 | 02:12 PM
Zerokube's Avatar
Also need someone to link me the smooth bellow diy site, cant find it anywhere
Old Feb 23, 2009 | 04:40 PM
teke184's Avatar
don't do the smooth bellow.
the one you get from places like SLP is 99.9% visual mod.
and there have been issues with lids cracking when using the none flexible fernco pieces. the engine twists alot under load.
Old Feb 23, 2009 | 11:20 PM
z28241's Avatar
Port your throttle body and do bump stop mod as well..
Old May 13, 2009 | 08:58 PM
Question
How do you reroute the coolant around the throttle body? And what is the bump stop mod?
Old May 13, 2009 | 09:09 PM
FirstLSx's Avatar
I just bought a 2 foot 5/16" coolant hose from carquest for $1.50 to bypass the throttle body, makes for a pretty clean look.
Old May 13, 2009 | 11:07 PM
z28241's Avatar
Bump Stop Mod> If you manually open your throttle, you will wee the manufacturer has the casting where the throttle will hit and stop at WOT, notice the throttle plate is not completely open, its about 90% open, so you carefully grind the casting material so the throttle opens all the way, when done properly, you would look at the front of throttle body in the WOT position and see the plate is straight across, equal space top and bottom, like a minus sign hehe.
