Porting LS6 Intake
Old Feb 23, 2009 | 11:30 AM
KH504's Avatar
Default Porting LS6 Intake
Has anyone ever ported a LS6 intake and got any gains ?
Old Feb 23, 2009 | 11:36 AM
the jester 812's Avatar
how can you port plastic?
Old Feb 23, 2009 | 11:43 AM
lifeisgood's Avatar
lmao.
Old Feb 23, 2009 | 11:47 AM
b00sted's Avatar
With porting bits and a dremel tool...goof ball.
I've seen a few ported LS2s floating around out there that work good.
Old Feb 23, 2009 | 11:51 AM
lifeisgood's Avatar
im sure its quite easy to screw up the ports....get carrier away and your fucked
Old Feb 23, 2009 | 01:27 PM
a-low's Avatar
If I remember correctly a sponsor here ports them for around
150.00 I just cant remember who.
Old Feb 23, 2009 | 04:43 PM
teke184's Avatar
not much to be gained.
porting plastic is easy, as long as you know how much material you have to work with.
the FAST is designed for porting in mind. i did mine with a dremel and those tubular sandpaper bits.
material comes off fast (no pun intended)...so you have to be carefull...very easy to go too far.
