500 hp cam
Why do you want 500hp? Did you pick a number out of the thin air? Do you feel you need to make some club, or wear the number like a girl wears expencive cloths?
Have you driven 500hp? A number isnt a tangable goal, I can make you a 500hp dyno graph out of any pull you want. A goal should be tangable, and more like real " I want to run 11s"
I want to ask this in about 20 threads a day and dont......but I have to ask someone.
haha ouch
i know you will...haha
edit: I just read the rest of the thread.. Check out my sig. I didn't make 500rwhp I made 447rwhp. My car is a full weight N/A 3600lb, stock bottom end, stock suspension car that ran that same #'s back to back at the track. I am using the Trick Flow 215cnc heads milled to 62cc with a cam Allen Futral cut to match these heads.
