Oil Flow Direction to Filter
Hi all
I need to know on an ls1/lq9 block where the oil pan bolts up and you have the two oil passage holes, which one of those holes if the feed to the oil filter? I am using a custom oil pan with 2 -an fittings that are going to feed my remote oil filter and cooler and I dont know which one should be the "IN" on my remote filter. Thanks so much in advance im litterally tightening the lines the second i get a solid response.
TIA
Tom
TIA
Tom
