LQ4 Questions
Old Mar 2, 2009 | 06:47 PM
nineeights10ss's Avatar
anyone?
Old Mar 2, 2009 | 07:06 PM
Also does anyone know with the utmost certainty that a t56 will match up with an '01 lq4 with no problems ( I know 99 and 00 will not, but I have seen others say 01 is a problem too) As long as its an aluminum headed lq4 it will match up?......anyone?
Old Mar 2, 2009 | 07:48 PM
NemeSS's Avatar
a t56 will work if its not a large flange 6.0.
will need fbody pilot bearing and fbody t56. bolts right up
Old Mar 2, 2009 | 07:54 PM
yeah thats what i am getting at, if it has aluminum heads its NOT a large flange 6.0 right?
Old Mar 2, 2009 | 07:56 PM
NemeSS's Avatar
correct.
large flange sticks out around .400,
normal flange is pretty much flush with rear main seal
Old Mar 2, 2009 | 07:59 PM
Thanks again!
Old Mar 2, 2009 | 08:35 PM
billyflantos's Avatar
i bought 799 heads and milled them .040 and put .040 cometic head gaskets on it and i used a polluter cam,but had to fly cut the pistons.very pleased with the motor......
Old Mar 2, 2009 | 08:41 PM
NemeSS's Avatar
sounds like strong running setup
799 are quivalent of 243
Old Mar 3, 2009 | 08:01 AM
BlueZee28's Avatar
Originally Posted by sroach20
99-00 were the problem 6.0s. what is this going in?
Not as big of a problem as most people claim. Swapping the crankshaft for an LS1 crank, or even an LQ9 crank, will solve the trans fitment issues.
Old Mar 3, 2009 | 08:51 AM
sroach20's Avatar
then you have to re balance the rotating assembly.
Old Mar 3, 2009 | 09:22 AM
BlueZee28's Avatar
Yea, it's really not a huge issue though. If you pick up a '99 or '00 block for a good enough price it's worth it. That's what I'm doing currently. Besides, I would have gone thru the block to replace parts even if it were a newer block anyways, so swapping the crank isn't going to kill me. I'm putting new bearings, rod bolts, lifters, and a cam in it as well as the crank before I put it in the car.
Old Mar 3, 2009 | 11:42 AM
  #32
NemeSS's Avatar
actually i prfer the large flange 6.0 since the offset of the crank is correct for use with a th350/400 without the spacer, hughes makes a sbc flexplate with ls crank bolt pattern.
Old Mar 3, 2009 | 12:05 PM
  #33
BlueZee28's Avatar
What is this flange thing that I keep hearing about? Is that another part you have to swap out to make the T56 work on the older LQ4? Is it actually ON the crank? Like I said, I bought a crankshaft from a 2006 Corvette that I'm going to swap into my motor so I can use a T56, but I keep hearing about this crank flange. What the crap is that?
Old Mar 3, 2009 | 12:10 PM
  #34
NemeSS's Avatar
u do not have to worry about it if your crank is 01+
99-00 and even some 01 6.0 were equipped with cast iron heads and the rear
of the flange was thicker than normal. the newer 6.0 just use a standard 3.62 crank along with spacer for use with 4l80e
Old Mar 3, 2009 | 12:19 PM
  #35
NemeSS's Avatar
that 06 c6 crank is gonna be 58x
Old Mar 3, 2009 | 12:21 PM
  #36
BlueZee28's Avatar
Yea I know. I am going to have the machine shop that will balance the rotating assembly for me, also swap the reluctor wheels from the cranks.
Old Mar 3, 2009 | 12:48 PM
  #37
NemeSS's Avatar
any machine shop that is familiar with ls engine should have the goodson tool on hand, or should refer you to a shop that has the capability to install and remove correctly
Old Mar 3, 2009 | 02:01 PM
  #38
01cherryreds10's Avatar
NemeSS thanks for all the info about the 317's!
How will that setup react to the heads if they aren't milled?
Old Mar 3, 2009 | 09:03 PM
  #39
Hi-Po's Avatar
Originally Posted by zx9rgreen
I went with 5.3 heads milled .02" to bump the compression. I also ended up having to cut the pistons for the 236 dur cam.
What lift on that cam?
Old Mar 3, 2009 | 09:42 PM
  #40
zx9rgreen's Avatar
.607"
The heads also have 2.04-1.58 valves. The only clearance issue was on the outside lip of the piston, the dish had plenty of clearance.
