LQ4 Questions
Also, this is on a 110 ICL
243 at 65cc
mill the heads .030 for just under 10:1 scr
a ls6 z06 cam from 02-04 will put your engine around the 400-420bhp range.
with milled heads, ls6 intake and even with stock manifolds. use ls6 rod bolts with the rods, to keep the price low. speed pro makes excellent replacement pistons and rings which cost around 400$ or less with rings. up to .060 over bore
As far as the early crankshafts (99-00) goes, the rear flange area was 1.25 wide or thick how ever you want to describe it and have a Casting number 12552215
The Noramal size ones for 01 - up should measure approx .860 wide/thick and have a Casting number 12552216
Here is some info with pictures...
http://www.enginebuildermag.com/Arti...ankshafts.aspx
5.3L, 5.7 LS1 and 6.0L are the same exact crank... They are how ever Balanced differently for there specific set up. A true LS1 crank also had a 1 Inch hole gundrilled through the center of the mains to help save weight. The all share the same Casting number 12552216
Here is a side by side crank picture.
https://ls1tech.com/forums/876185-post19.html
