hotcam max rpm's
Old Oct 15, 2003 | 06:48 PM
sleeperz28's Avatar
Default hotcam max rpm's
With hardend pushrods would the springs that come with the hotcam be ok to rev to 6600rpm on a regular basis? If not what would the max safe rpm be?
Old Oct 15, 2003 | 06:51 PM
SSean's Avatar
Default Re: hotcam max rpm's
The springs that come with the hot cam are LS6 springs. I'm not sure how high you can rev them, but I could think 6600 should be OK. I dont know how much hither I would go though. Do you have a hotcam? does it really need to rev that high?
Old Oct 15, 2003 | 06:56 PM
sleeperz28's Avatar
I'm getting one. Just want to know if it will be ok if it does benefit. My rev limiter is set that high right now.
Old Oct 15, 2003 | 06:59 PM
BillWS6Formula's Avatar
I've had my revlimiter set to 6600rpm with the Hotcam, LS6 springs, and stock pushrods for over a year now with no problems. I get my best times at the track by shifting as close to the new limiter as I can.
Old Oct 15, 2003 | 07:03 PM
sleeperz28's Avatar
billws6formula do you have any tuning other than hypertech? My car cam with the hypertech tuning but not the tuner. Have yo had any problems with hypertech. Only thin I notice is that on hot days at the track with a stock motor I get knock retard causing me to lose .3-.4 in the 1/4. Does this timing help with the hotcam?
Old Oct 15, 2003 | 07:32 PM
Right now I'm only using the Hypertech for the revlimiter, speed limiter bump, and 4.10 gear change. I do use a MAFT as well, but that was to adjust for a rich condition after adding the FLP longtubes.
Old Oct 16, 2003 | 09:02 AM
SSCamaro99_3's Avatar
My Hotcam makes max hp at 5950 rpms.
Old Oct 16, 2003 | 11:09 AM
SilverGhost's Avatar
Motorboater
I had a hotcam a few years ago, had it for like 2 years with the springs it comes with and hardened pushrods..ran it to 6500 rpm countless times in that period with no problems.
Old Oct 16, 2003 | 12:36 PM
TaTommyWS6's Avatar
I have my hotcam rev limiter set for 6500. It never really peaks, just platues...
http://www.tatommy.com/dynoruns.htm
Tommy
