underdrive pulley
Old Mar 8, 2009 | 07:54 PM
1fastmofo's Avatar
Default underdrive pulley
does anyone have any experience with one that is fluid filled? is it better or worse? any info is appriciated
Old Mar 9, 2009 | 06:02 PM
1fastmofo's Avatar
no one has ever use a fluid filled balancer?
Old Mar 9, 2009 | 06:09 PM
Sleeping00Z28's Avatar
I have one. They are better, less vibration on the crank and chain. the stock one is fluid filled. Plus it is SFI approved if you go March like I did. It was a sexy looking piece as well. Plus it comes with an overdrive pulley for the Alternator so you dont loose any battery power.
Old Mar 9, 2009 | 06:55 PM
SOMbitch's Avatar
^^^^^^^^Incorrect/bad info..funny........ Stock is not fluid filled.Wake up...... I have a March too... The general consensus is that that ATI is the best out there.
Old Mar 10, 2009 | 07:27 PM
1fastmofo's Avatar
so can anyone source some other experience with the balancers
Old Mar 10, 2009 | 07:48 PM
black01_WS6's Avatar
almost all of them are the same. look for ones that have a raised lip so you don't throw the belt off at high rpm. Just keep an eye out for one that is on sale, unless you need this one now. I have a powerbond one and I have never had a problem with it.
Old Mar 10, 2009 | 08:00 PM
buckner01's Avatar
can you make more power with them?
Old Mar 10, 2009 | 08:03 PM
you can make around 10rwhp with a cam. You really only see it in the top end. I would only put one on when doing a cam. Its one of those might as well while you are in there type of things.
