Another 918 down the drain.
Old Mar 10, 2009 | 02:52 PM
GTABurnout's Avatar
cheaped out on the springs why run to the limit....
921's should have been used
Old Mar 10, 2009 | 06:08 PM
hirdlej's Avatar
I said it before on pt.net and I'll say it here. It looks to me that the spring is not only broken but the bottom looks bent. Looks as though the spring was done in by coil bind. Does anyone else see what I'm seeing here or am I looking at it different than everyone else?
Old Mar 10, 2009 | 06:54 PM
Red99TA's Avatar
I would wait for install specifics before blaming the springs too although I know Comp has had issues in the past with the 918's. I ran these with a .603"/.600" lift cam for 12K miles with zero problems. The 918's were originally rated to .625" lift before they came out with their duals then they reduced its "rating" to .600" to get people to buy the duals.
Old Mar 10, 2009 | 06:56 PM
SweetS10V8's Avatar
I see what your saying....The old 918s with the blue stripe that were having the issue were breaking the tips of the valvespring. This one needs to be researched.
Old Mar 10, 2009 | 07:36 PM
vettenuts's Avatar
See post 15 and 20.
Old Mar 10, 2009 | 10:15 PM
RE AND CHERYL's Avatar
Originally Posted by 1BADTALS1
first time ive heard of the 918's having problems i got them with my cam .581 lift 112lsa and they been in for about 20k miles...no problems at all...
What rock have you been living under.
Also...He said they were the new 918s. I thought the new design was rated for .625 or .650 (can't remember which) and the old design was rated for .600. Either way, it a bad day.
Old Mar 10, 2009 | 11:51 PM
Damian's Avatar
LSX Mechanic
Originally Posted by vettenuts
Everyone is blaming the spring with no information on the installation. My money is on installation issues.
Thank you, I was just about to type those exact words.
So on this engine, was preload checked? Pushrod length checked? I'd bet $100 somebody threw a 7.4 pushrod in that motor, TQ'd it to 22ft lbs and went about their merry way.
Old Mar 11, 2009 | 10:32 AM
hirdlej's Avatar
I'll bet you $500 I know from reading the post in the other forum where this occured that the end user didn't know the installed height of the spring. Just threw them in. I think that's what happened here and coil bind was achieved. That doesn't look like the old broken 918 problem where they'd break on the top coil. It looks all jammed up in the bottom like the coils bount up and the rockers smashed it to ****.
Old Mar 11, 2009 | 10:38 AM
gayslowassNALSjunk's Avatar
Originally Posted by cam
I have no idea why anyone uses those single beehive comp crap springs. I understand the science behind them and all the hooplah but the proof is in the pudding and I see all sorts of breakage complaints with these. I've never seen ONE single complaint of breakage on Patriot Golds yet and they cost less.... Why everyone doesn't run them boggles my mind
I managed to break a Patriot Gold with a Torquer v3 cam. I was just idling through a grocery store parking lot when it happened.
Old Mar 11, 2009 | 12:57 PM
Patrick G's Avatar
LS1 Tech Administrator
You were running a .64X" lift cam. Those take special spring and pushrod prep. Ideally, you should run shorter pushrods on the exhaust lobes and you need to make certain that your springs over your intake valves have enough installed height to keep you out of coil bind (see installation error).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 11, 2009 | 01:24 PM
AU N EGL's Avatar
370 244/248 .612/.615 112 lsa LS6 Heads Milled .030
Did not think 918s were designed for lift above .588 - .600 or so. ??
Old Mar 11, 2009 | 01:54 PM
  #32
Touche about the pushrods. I was taking the word from TSP that the 7.4s would be fine.
Old Mar 23, 2009 | 05:21 PM
  #33
02WSsicks's Avatar
Broke my 918 at idle in my driveway Stock Z06 cam
Old Mar 24, 2009 | 12:58 PM
  #34
zman1969's Avatar
Default springs
People often take things for granted, and this can and will happen again. I decided to use the tried and true TR224/224 112 in my motor (LS6) with Livernois heads and .690 lift springs not by choice but thats what they had when I got them. Sure I want Huge power but settled for a smaller cam to be easier on related parts. I don't want to be worried on my cross country trips that something is gonna snafu , I want OEM reliability and more power. OK maybe I'm a wuss but if your going with extreme parts - wheres your backup? a single spring? what I dont understand is Comp 918s with Tit retainers are a bunch more than Patriots so why do so many have them? Im kinda old school - when a SB with .450 lift was a big cam-now im thinking my 224 cam is BIG -well not compared to whats out there now buy you cant skimp -ESPECIALLY on springs and expect it to live.
Old Mar 24, 2009 | 01:22 PM
  #35
52172's Avatar
what about the way the spring was broken in? Comp says to do a couple heat cycles on them before normal driving?
