Whats the current best head on the market?
Old 03-10-2009, 09:43 AM
ramairroughneck's Avatar
Thr fastest stock bottom end car in the country uses PRC 215s. These heads also have better ptv than the other heads mentioned and are cheaper.
Old 03-10-2009, 11:17 AM
Dragkid1917's Avatar
I always thought the Trick flow 215's had the advantage with ptv clearence because of there 1.5 degree change in port angle (15 to 13.5 i think). Ive always herd the TFS 215's are the way to go. They do however require a new rocker setup. Im sure if you get a pair milled and worked over theyll make insane power.
Old 03-10-2009, 11:33 AM
streetassasin's Avatar
Originally Posted by evangto87
285 cfms at 600 lift without use of a pipe. Off the shelf heads use a pipe. Pipe is worth a solid 25 to 30 cfms
my prc 5.3's flow 312 at .600.......
Old 03-10-2009, 12:11 PM
99blancoSS's Avatar
There are going to be many answers here, there are a few good proven performers but the most important thing is the whole setup.
Weight and gearing and traction play a big part of it at the drag strip but in full weight street cars results are going to be different. It's not just about flow numbers of a head on a bench. There is much more to it than that.
Old 03-10-2009, 09:01 PM
theblur98ss's Avatar
When I was looking it was between afr and etp. I got a nice deal on a set of etp's so that's what I'm running. I had a set of 243's done by GTP years ago that outflowed alot of big $$$ heads.
Old 03-11-2009, 09:34 AM
LS1Tech Sponsor
TrickFlowTech's Avatar
Originally Posted by nitrorocket
I need to pickup some heads fora big power stock bore pumpgas N/A project. Who ports the most efficient heads right now? I need to buy a set...
What cubic inch motor are you building? How much power are you looking to make? Give more details and I will be more than happy to help.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 03-11-2009, 10:17 AM
nitrorocket's Avatar
It is for a stock bore ls1. Stock bottom end.
Basically need heads, cam, has headers and ls6 intake and needs big power on 93 octane fuel...
Old 03-11-2009, 12:44 PM
LS1Tech Sponsor
Well with our 215 head and our stage 4 cam using what you already have will produce around 530 HP and 470 ft lbs of torque at the crank.
__________________
