cam specs
Old Mar 10, 2009 | 01:55 PM
Texass683's Avatar
Default cam specs
just wondering what kind of added power would i be looking at getting with this cam set up
218/228 .525/.525 112lsa
Thanks in advance. I am completely stock as of now
Old Mar 10, 2009 | 01:57 PM
streetassasin's Avatar
Hot cam? Maybe 20-30 rwhp But get long tubes and a lid first
Old Mar 10, 2009 | 02:00 PM
teke184's Avatar
low duration, really low lift.
hardly worth the effort unless you needed emissions friendly.
Old Mar 10, 2009 | 02:01 PM
Texass683's Avatar
not really needing emissions friendly cam but just wondered. Its for sale really cheap just wondering if it would be worth the effort but i dont think it will be
Old Mar 10, 2009 | 02:06 PM
NOBR8KSS's Avatar
Sounds like the GM Hot Cam....usually see folks put down about 380-400 rwhp with all the bolt-ons and the Hot Cam. It's easy to tune and is easy on valve springs.
JC
Old Mar 10, 2009 | 02:35 PM
teke184's Avatar
unlikely to hit 400rwhp without some head work.
its not a horrible cam...but its pretty old lobe technology and a very conservative grind.
Old Mar 10, 2009 | 02:37 PM
Havok2's Avatar
i wouldnt waste my time with that cam. thats what some consider a baby cam.
i dont see you gaining 30-40 hp from it tho.
Old Mar 10, 2009 | 03:10 PM
hammertime's Avatar
The best advice you'll ever get is to make sure your camshaft selection matches your application. Without telling anyone what you want to achieve, it's pretty tough for anyone here to tell you that is a bad choice.
That cam with bolt-ons and some budget LS6 heads could make for a 400wrhp setup that drives like stock only with more power everywhere. Yes, other cams out there have a greater following and will make more power at higher engine speeds, but the choice still depends on what you are trying to do.
Old Mar 10, 2009 | 03:22 PM
dre2013's Avatar
you'll regret it if you get that cam. i had the hotcam in an lt1 i had a few yrs ago and it was slow as *****. bolton lt1's would almost get me....and i had all the boltons. not worth the time/money for that swap. i wouldn't go anything smaller than a 224 cam
Old Mar 10, 2009 | 04:32 PM
HTX's Avatar
HTX
you would benifit more from boltons. that cam would be alot of work for not much of a gain. im guessing 20rwhp
Old Mar 10, 2009 | 05:33 PM
Texass683's Avatar
cool thanks guys i appreciate the input ... i will probably be going with something in the 220 to 224 range
Old Mar 10, 2009 | 05:36 PM
SOMbitch's Avatar
224/224 is the minimum worth the effort IMO. You can see I didn't go much bigger though...
