Engine? Vibration - Help!
Old Mar 13, 2009 | 11:10 PM
RevGTO's Avatar
Pontiacerator
Default Engine? Vibration - Help!
A friend had his 01 Formula in my buddy's shop today. Car is M6, lid and catback only, 91k. His engine idles roughly, and develops a pronounced vibration @ 1200-1300 rpm in neutral that gradually smooths out as the rpms increase. It's enough to shake the steering wheel and other interior pieces in the affected rpm range.
A tech checked the injectors and scanned for misfires. Injectors were all in spec and there were zero misfires in that rpm range. No misfire codes, either. Plugs and wires are new. No unusual noises or anything.
The car seems to pulll out and drive normally with no loss of power, although the engine seems a little rough.
The tech feels it is an imbalance in the rotating assembly somewhere between the harmonic balancer and the flywheel. He doubts that it's the flywheel and says that if it was, the vibration would continue up the rpm band. LUK clutch is fairly new.
Any tips or help from your experience would be appreciated. He's pretty frustrated.
Old Mar 13, 2009 | 11:16 PM
DaddySS's Avatar
fix the rough idle first, then see what you have
Old Mar 14, 2009 | 09:10 AM
RevGTO's Avatar
Pontiacerator
The rough idle isn't a distinct symptom from the vibration - it's an aspect of the same thing.
Old Mar 14, 2009 | 04:06 PM
up2nuthingud's Avatar
motor mounts maybe shot?
Old Jun 12, 2009 | 03:58 AM
99RedTa6spd's Avatar
Angry same here
my 99 with 90k does the same thing..... my shifter and steering wheel shake bad at that rpm range.....
Old Oct 26, 2009 | 03:32 PM
6.0 silverado's Avatar
Anyone figure this out? My car also vibrates just off idle and smooths out a little at higher rpms. It idles smooth as butter, but the off-idle vibration is driving me nuts
Old Oct 26, 2009 | 03:38 PM
King Nothing's Avatar
yeah mine is doing it also, but i have 160K on it so i'm used to it now with my exhaust lol
Old Oct 26, 2009 | 05:02 PM
does anyone think a fluid damper under-drive pulley would help anything? Has anyone tried it?
Old Oct 26, 2009 | 05:05 PM
LS1BLKSS's Avatar
Banned Village Idiot
put some poly motor mounts
Old Oct 26, 2009 | 06:50 PM
I have prothane motor/tranny/TA. I thinking of removing the tranny mount for a stocker to see if it will help.
Old Oct 27, 2009 | 12:25 PM
Johnnystock's Avatar
Dont do this, I have poly motor/tranny mounts and no vibration at all. I know I had a misfire and would make the car shake bad and run weaker; One wire wasnt fully popped in...I would re-check that honestly before going further.
What plugs he is using by the way?
Old Oct 27, 2009 | 03:38 PM
I don't have a miss. The car still runs strong, idles smooth and there is no CEL. Maybe I'll start looking at the flywheel/ pressure plate or the accessories. I believe the vibration has been there for quite some time, but the prothane mounts made it more pronounced.
