Question About Intake and Valve Cover Gaskets
Old Mar 15, 2009 | 08:20 PM
TORCHD 02 TA's Avatar
Question Question About Intake and Valve Cover Gaskets
Today i jsut pulled my valve covers off b/c i am going to be painting them. And next weekend, same thing i am pulling my intake off to paint that too. My question is do i need to replace the gaskets for the valve covers and intake?
If i am not mistaken, the valve cover gasket is an o-ring type gasket and you do not need to replace those? Also the gasket stuck to the valve cover now, i am going to pull it off, when i put it back on do i put some silicone down to make it stick? If i do, what type of silicone do i use?
And i will prolly replace the intake gasket, b/c if i am not mistaken once it is crushed, you can not reuse it? Other wise you will prolly get a CEL and be running lean b/c of a vacuum leak?
Thanks
Old Mar 15, 2009 | 09:45 PM
SOMbitch's Avatar
I have pulled mine off a couple different times and reused them so if you are careful you should be fine...
Old Mar 15, 2009 | 11:23 PM
What part that you took off are you referring to?
Old Mar 15, 2009 | 11:42 PM
02BLKWS6MD's Avatar
you can reuse valve cover gaskets if your careful. I wouldnt reuse intake gaskets though, might get a leak, I wouldnt reuse them at all. Even when I do my camswap Im not even reusing the valve cover gaskets Im just replacing them.
Old Mar 16, 2009 | 06:43 AM
SweetS10V8's Avatar
They are absolutly reusable if they dont get cut. Ive had them on and off over and over and over on many LS engines.
Id be broke if I had to pay for new gaskets on these things all the time....
Old Mar 16, 2009 | 09:37 AM
I think i am jsut going to buy new valve cover gaskets. jsut for safe insurance
Old Mar 16, 2009 | 09:55 AM
jmm98LS1's Avatar
I've got an extra set of new valvecover gaskets (still in package) I'd give ya dirt cheap if ya want em.......shoot me a pm if so.
Old Mar 16, 2009 | 11:51 AM
What brand are they? Thanks
Old Mar 16, 2009 | 01:50 PM
jmm98LS1's Avatar
GM, got them from GMPD.
Old Mar 16, 2009 | 03:33 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Valve cover gaskets = reusable
Intake gaskets = reusable
As long as they aren't ripped/torn/frayed, there is no reason why they can't be reused. As already stated, if I replaced the gaskets every time I had either of those components off, I'd be broke.
