Tell me its not that bad.
Old Mar 16, 2009 | 08:09 PM
Art Vandaley's Avatar
Default Tell me its not that bad.
So tell me if I messed up bad
My car has been broke since November 6, 2008, due to shitty stock hyudralics, i managed to break my 2nd gear. My transmission has been out of the car since the end of November and has been sitting ever since at school in pieces (sigh). I am just saving up very very slowly for my rebuild I want. (tick stage 2, and tick adj. with new slave and second). Now comes to ?. am i looking into more problems because she has been sitting so long. The car has been sitting with a cover on it and battery disconnected for over 4 months. Will I have to replace all the tires (flatspots)? Will the car start? I did not put stabilizer in the gas tank. The ypipe is resting on the ground... does that mean that contaminants could of got up to the block and now my engine is toast? I really dropped the ball in not worrying about these things earlier.. wow im dumb. Any help would be appreciated.
thanks ls1tech.
Old Mar 16, 2009 | 08:32 PM
styoung's Avatar
i wouldnt worry too much, a lot of people let cars sit far longer than 4 mo. with out issues. i just let my car sit all winter with the battery still connected and no stabil in the gas and it started right up. so you should be good.
ITS NOT THAT BAD!!! lol
Old Mar 16, 2009 | 08:33 PM
Magic Man's Avatar
It's ok might take a few laps around the block to get the tires round.Car will have to relearn everything but that won't take long and you might have a few spiders hiding in there but it will be good to go.
Old Mar 16, 2009 | 08:42 PM
Sid447's Avatar
Engines that have sat for 30 years,
and more have been cranked into life. Four months is nothing, just take a good battery with you and give it a good long crank with the fuel pump fuse or relay out to get the oil pressure up, before you fire it up.
Old Mar 25, 2009 | 10:15 AM
SSJIMMY's Avatar
mine sit for almost 6 months when i purchased my DD and it was fine filthy but started up just fine.
Old Mar 25, 2009 | 10:27 AM
gyrene2003's Avatar
hope for the best plan for the worst. I was deployed for 15 months, granted car was started avery few weeks and i did have stabilizer in the tank, but she ran just fine when i came home.
Old Mar 25, 2009 | 11:15 AM
intake68's Avatar
Hahaha up here in Canada my car went into storage in October. I will hopefully get a chance to bring it back out in the next two weeks.
I simply disconnected my battery just like every year. When its time to go in the spring I hook the battery back up and fire it up.
I always have a full tank of gas on the car and change fluids the first day I take it out of storage.
Your car will be fine
Old Mar 25, 2009 | 03:33 PM
DmesticDstrbance's Avatar
Just started mine for the 1st time in about 3 years and it fired right up.
Put some seafoam in the tank just in case if you're worried, but I wouldn't be.
BTW don't ever say your car is BROKE.
Old Mar 25, 2009 | 04:54 PM
DaveX's Avatar
It's not that bad.
Old Mar 25, 2009 | 05:51 PM
greatskiiiier's Avatar
my car sits for ~5 months at a time depending on whether or not i go home during the semester (college too), every time i come home the battery has been dead so i just bought a trinkle charger and a cover... my SOB dad never touches the car no matter how much i ask and last time i went home mold developed inside the car pretty bad.... cost him a pretty penny for the detailing- paybacks a bitch
Old Mar 25, 2009 | 06:06 PM
ss.slp.ls1's Avatar
You're fine. Anything over six months I would recommend using stabil and setting the car on stands.
Old Mar 25, 2009 | 09:07 PM
Jon87transam's Avatar
dont worry, but id change my oil after first startup. just in case moisture has intruded due to sweating during climate changing. if it was in a heated area, may not have to worry about moisture so much, but if it were mine i would change it anyway. tires should come out of it...if not just "burn off" the flat spots on the back, then rotate tires front to back, and burn off again!!! but seriously, the tires should come back in a few miles on a warm road. having a LS1 down that long will make you appreciate it when you get back in it again-have fun!!!
Old Mar 26, 2009 | 08:08 AM
CodeRed2000SS's Avatar
the car is fine. nothing to worry about
Old Mar 26, 2009 | 09:15 AM
Rileyt's Avatar
4 months? thats not bad at all mine sits all winter long just not outside! at the most you will prolly have a dead battery or something but f its unplugged then it should recharge.
Old Mar 26, 2009 | 09:17 AM
Mr. Brett's Avatar
It's not that bad.
Old Mar 27, 2009 | 06:45 AM
cool thanks guys, didn't mean to sound like OH MY GOD lol, but never hurts to ask. Thanks a lot for all your comments.. and let me tell u.. I miss it so bad.
Old Mar 27, 2009 | 06:34 PM
stevied916's Avatar
you can make your own adjustable master to save money too. I have the die and nuts and could send them over. All you need is the adjustable ball joint part which is around $10-15 shipped
Old Mar 27, 2009 | 09:24 PM
JGKadell's Avatar
How would having your y pipe on the ground really affect anything?
Old Apr 1, 2009 | 08:32 AM
i was just thinking of **** crawlin up inside is all.
