How to remove ASP Pulley
Old Oct 20, 2003 | 11:42 AM
Beeler422's Avatar
Back in the staging lane
Default How to remove ASP Pulley
Well some idiot when we were installing the motor, broke off a bolt in one of the holes that the ASP puller connects to. Can you remove it by pulling from the outside with another style puller? I don't have the car here so I can't look and see exactly what the pulley looks like. Thanks.
Old Oct 20, 2003 | 11:52 AM
Scalpel's Avatar
Default Re: How to remove ASP Pulley
Just get an easy out, remove the old bolt and try again with a normal harmonic balancer puller. They have them at autozone.
Old Oct 20, 2003 | 11:54 AM
Beeler422's Avatar
I think they tried that at the time and it didn't work. I'll try it again, but if that won't work. what options do I have?
Old Oct 20, 2003 | 12:02 PM
Scalpel's Avatar
Hmmm, if that doesn't work it sounds like it'll be a nightmare. You could drill out the bolt, drill a bigger hole, helicoil it and then use a different size bolt in the puller for that hole.
How did they break the bolt off?
Old Oct 20, 2003 | 12:05 PM
Beeler422's Avatar
I think for some reason, they installed the pulley, but then decided to take it off. So they started pulling it but broke the bolt off in the pulley. I'll have to look at the pulley again later and see what it looks like. It's been forever since I've seen it. I was just thinking about a cam swap and thought about it. I guess I could retap it though if I have to.
Old Oct 20, 2003 | 12:07 PM
Beeler422's Avatar
just noticed this was in the internal forum; one of the mods wanna move this for me? Thanks.
Old Oct 20, 2003 | 12:08 PM
jmX's Avatar
jmX
Every time I've pulled an ASP pulley off (at least a dozen) I've used the normal 3 jaw puller. You can pull from the ridge between the AC belt grooves and the main belt grooves. Works perfect every time.
