How much rwhp after cam/tune?
im runnin the torquer 2, im an m6 and its very smooth on the road. no bucking or surging. i made 390rwhp and 370rwtq on a crapped out exhaust and 10 bolt. i swapped to QTPs/true duals and did a rear end swap with 4:11s and it made 395 or 396 i believe?
I'm running tsp 228r with ported 241's numbers and my sig and I bet if I get on the dyno again I will go higher my motor was stupid hot when we did the final pull
2 questions.
1. arent you running very close to the max lift for those springs with that set up?
2. ive done a little searching about what motors had what heads. during my search i found that the LS2 and LS6 used different heads. but like you mentioned, and ive seen pics of a LS2 GTO, they have the 243 casting. My LS6 has the 243 casting as well. whats the deal???
SearayC5, I daily drive a F13 from Futral and its very smooth. This is with a 3600 stall. You need to look at hp/tq curves for mutliple cams. Futrals are proven and highly recommended around here.
Transam0486, I would stick to the F14. You should be around 410ish-420ish. You should probably get some higher lift, double springs. I just got a Patriot Gold Dual kit for $255 shipped.
