Crank sensor problem/question
if you drive the car (no matter how far) and then pull over and cut it off for a couple on minutes, then restart, the car does start and idles fine, but when you go to pull off it acts like it looses half of it's power, stumbles very bad, and then clears right up and goes on.
What could cause this and NOT set a code.
I have replaced the plugs, wires and injectors, the MAF is clean
Note:
I did have the crank sensor wires and the low temp oil light wires get close enough to the headers to melt them semi together,,,,And I thought that had to be the problem, I got the apart, and reinsulated them,and it did not cure the problem
Shane
