GUESS MY Horsepower
Old Oct 21, 2003 | 08:45 AM
PurEvl's Avatar
Default GUESS MY Horsepower
Lets see who can guess what this motor is or should be making. I will post what its done so far after
Mods:
LS6 block blue printed and balanced
JE Forged Pistons 3.905 bore
Custom heads w/ REV valves and crane true double springs milled .055 flowed 305 at .550
thunder 230/224 110.3 LSA cam titanium retainers, 7.350 hardend push rods, yella terra 1.7 rockers
1 3/4 full length hooker headers
true dual x pipe setup
ported and polished tb
slp 85mm maf
K&N FIPK
ls6 intake manifold
mccloud clutch and adj master
Moser 12 bolt 33 spline eaton posi with 4.10
ultra z funtional ram air hood
FTRA KIT
MSD Wires
NGK Tr55's
SLP Double Roller Timing Chain.
ATI Super Damper
GO!!
Old Oct 21, 2003 | 11:41 AM
onyxxtreme's Avatar
Default Re: GUESS MY Horsepower
i guess 430 range at the wheels
i dont know really, but i am wondering what type of heads your gonna use
Old Oct 21, 2003 | 11:45 AM
XFACTOR's Avatar
I say 440-445 rwhp!!!!!!!
Old Oct 21, 2003 | 02:46 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Your comments about your heads are pretty vague, are they fully ported heads?
I'll say 440rwhp with ported heads.
That clutch company is spelled McLeod.
Old Oct 21, 2003 | 07:20 PM
PurEvl's Avatar
flowed 305 at 550 lift 271 with ls6 intake attached, stock size valves, There Revs cut back to stock size. Thanks I was in a rush writing it so the spelling isnt great
Old Oct 21, 2003 | 07:38 PM
Slowhawk's Avatar
LS1Tech Sponsor
360hp
Old Oct 21, 2003 | 08:12 PM
Hitman#1's Avatar
Leventy-leven. :p
Old Oct 21, 2003 | 08:31 PM
SPANKY LS1's Avatar
410-420
Old Oct 21, 2003 | 08:37 PM
andy98Z's Avatar
What Compression ratio? 410-420 Mustang Dyno, 430-445 dynojet
Old Oct 21, 2003 | 09:07 PM
PurEvl's Avatar
11-5ish compression
Old Oct 21, 2003 | 09:09 PM
PurEvl's Avatar
360hp
you tuned it!
And no its not that low
Old Oct 21, 2003 | 09:44 PM
98TAauto's Avatar
i bet you make over 300 atleast LMAO
its hard to say.. 420+ atleast
im gonna say 442
Old Oct 22, 2003 | 08:11 AM
PurEvl's Avatar
well I thought for sure I would be in the 430-450 range as well. Im barely over 400
Old Oct 22, 2003 | 09:20 AM
Krazy98Z28's Avatar
At least your over 400
Old Oct 22, 2003 | 09:34 AM
GueSS Who's Avatar
moser takes some power away. I am going to say 420-430.
Old Oct 22, 2003 | 09:42 AM
jRaskell's Avatar
Just curious, why would you go through all that effort only to keep the stock valve sizes? Nice flow numbers, but still...
Old Oct 22, 2003 | 10:05 AM
PurEvl's Avatar
Alot of head porters dont believe low cubed motors benefit from bigger valves. If anything it can hurt. From what I understand it can mess with velocity as well. LS1derfull can shed some light if he comes in here. Im no head expert
Old Oct 22, 2003 | 11:09 AM
xp3nd4bl3's Avatar
Moderator
Race-Prep put 2.08/1.60 valves on my 6.0L heads that went on my stock bottom end 346. The car made 450/410 with a 230/236 cam through Mac headers.
Old Oct 22, 2003 | 11:18 AM
onyxxtreme's Avatar
i dont see how a 2v stock cubed motor wouldnt benefit, from slightly oversized valves
