Metal Shavings.....
all the stuff wiped onto the paper towel is metal shavings, there was also a 4th chunk about the same size as the largest one that I dropped and couldn't find.
is this bearing material?
how bad is this? car seems to run fine.
Chad
Chad
I suggest getting a long magnet type stick that extends like an antenna and is bendable. Stick it in the oil pan drain hole and sweep the entire bottom of the pan a few times to get all potential pieces out of there.
Are those pieces magnetic?
which means bigger, stronger, faster.
Chad
I forgot which part that is though. From memory, I think the spring retainers in the heads or maybe the spring seats.
At least those parts can be ruled out.
just going to wait, drive it normally and change the oil in a month or so do the telescoping magnet stick and see whats up.
Chad
edit: also, do you happen to have the oil filter you took off it? might want to cut it open and see if there is anything suspect in there as well...
