TR Raptor Cam Only Results
having numerically lower gears in the rear will actually net u more whp. mustang dynos actually read higher than dynojets most of the time, depends on how the person has their rollers set. and lastly im guessing from ur sig u have a 2000 model year, u may want to check ur tune, the 00 have the smallest injectors of all the other fbodies, with ur mods u should be making into the 400s easy they have to be on the brink of maxed out. but by the numbers the dyno pull said ud run id say they probably have their rollers set pretty tight and thats why ur numbers r low
You're the only person then....Dynojet's always show better numbers. Is it possible one of your dyno sheets shows the adjusted numbers vs one that does not. That will make a big difference.
Either way, to the origional poster, those numbers are not bad considering your combo and dyno used. Lower numeric gears will create a higher rwhp btw
