Engine high rev in first before catching!!!
Old Mar 30, 2009 | 07:14 AM
flemshady's Avatar
Default Engine high rev in first before catching!!!
Ok, so as I go to accelerate everytime, my car will rev really high in first before it catches second. Trany? Or you think its something else..
Old Mar 30, 2009 | 11:01 AM
00Formula00's Avatar
4l60e?
Old Mar 30, 2009 | 11:27 AM
hadkin's Avatar
maybe you need to change your shift points of your tranny. two ways, buy yourself a hand held editor or go to a shop.
Old Mar 30, 2009 | 12:18 PM
flemshady's Avatar
4l60e yes.. and this just started happening. I have not messed with the shift points..
Old Mar 30, 2009 | 02:08 PM
dub.ya.es.SICK's Avatar
little tranny slippage?
Old Mar 30, 2009 | 02:17 PM
Wesmanw02's Avatar
Trans. Check the fluid level and make sure its clean.
Sounds like its time for a rebuild, unfortunately.
Old Mar 30, 2009 | 02:20 PM
LS1Z28-00's Avatar
is the tranny grabbing or does it feel low on power? Im not a tranny expert but if its just delaying going to next gear it could be like a bad/sticking solenoid or something? The car should hit the rev limiter before it revs to high i would think.
Old Mar 30, 2009 | 02:49 PM
im going with a worn tranny does it do it when you do 1 into 2 or just in drive? and when it grabs is it a rough grab into 2nd? id change fluid and filter and go from there
streetassasin's Avatar
trans is more than likely on its way out
Old Apr 1, 2009 | 03:41 PM
flemshady's Avatar
It doesnt go hard into second, just sorta transitions in, but it revs for a few seconds before it slips in, like a delay..
Old Apr 2, 2009 | 06:52 PM
regency's Avatar
like you a six speed car when you rev the motor then dump the clutch?? or like slipping the clutch on a six speed car?
Old Apr 2, 2009 | 07:52 PM
flemshady's Avatar
Like my catalytic converter went out and it was only breathing on one side.. Its fixed now. Thanks guys!!!
Old Apr 2, 2009 | 08:03 PM
joecar's Avatar
Hmmm... clogged cat was causing engine performance to die which caused PCM to incorrectly lookup/calculate transmission pressure settings... cool.
Old Apr 2, 2009 | 08:12 PM
lol woah.
