oil pressure
Old Mar 31, 2009 | 12:00 AM
billyflantos's Avatar
Default oil pressure
i have a ls6 blueprinted oil pump what should my oil pressure be at idle 1000rpm....
Old Mar 31, 2009 | 12:07 AM
massconfusion's Avatar
don't know for sure but my stocker on my 99 z28 with 94,000 on the clock makes about 45ish psi at idle so probably around 50 or so. you don't idle at thousand do you
Old Mar 31, 2009 | 09:16 AM
iguana's Avatar
40-55 psi at idle
Old Mar 31, 2009 | 09:52 AM
DONAIMIAN's Avatar
I know it most likely is, but is this going on a stock short block?
Old Mar 31, 2009 | 11:05 AM
dub.ya.es.SICK's Avatar
cold 50 55ish warm 45 50ish on mine 850idle
Old Mar 31, 2009 | 11:19 AM
60k on the 6.0 short block,are these numbers with the factory gauge or after market gauge?
