Question about LSA
Old Apr 5, 2009 | 08:58 PM
Shawn MacAnanny's Avatar
you're in GA, they dont have a emmissions do they? Just get a rediculously large cam like 280/280 .800/.800 104 lsa and trailer it everywhere
Old Apr 5, 2009 | 09:03 PM
Zach79Z's Avatar
lol no they dont have emmisions and that cam would be nasty to say the least lol
Old Apr 5, 2009 | 09:10 PM
lol i dont think it would run, clear you pistons, or even be driveable, but **** it, it would be like having a 28" *****.
Old Apr 5, 2009 | 09:14 PM
Zach79Z's Avatar
lol completly useless unless you find a bored out woman
Old Apr 5, 2009 | 09:16 PM
Haha yeah they do exist though! Let me tell you.... I would def go with the PAt G cam though. My cam is a Pat G cam, specd for another members motor though, but the specs i wanted for mine.
Old Apr 5, 2009 | 09:20 PM
Zach79Z's Avatar
LOL!!! Yeah i hear he does awsome specs and i can tell itll be what i want from all the questions he asked lol
Old Apr 5, 2009 | 09:23 PM
hammertime's Avatar
Originally Posted by Zach79Z
hmm...Sounds like something id like. I really want a torque car and want it at a fairly lower rpm (2500 or so) and i dont really wana turn the car up to 7000 rpms. But i dont know if itll be good if it maxes out at 6400 (so to say)
You probably don't want to go much larger than what you started with then. As a matter of fact, less is more as far a torque is concerned.
Depending on what lobes Patrick uses, I've seen him and Predator Z both spec a 224 XFI intake (comes in around 226 when cut) and a 230 XE-R on 111 LSA before. Would be a great cam for your goals and pull well past the peak. You don't have to have lots of duration to make power over 6000 rpms, and you can't have lots of duration if you want power under 4000 rpms.
Old Apr 5, 2009 | 09:27 PM
Zach79Z's Avatar
Yeah i dont really want past a 234ish duration cam. Id like to have power over 6000 but dont really wana hit 7000rpms and id like to have power around 2500-3000
Basically id like to have something around 230 232 around a 110. Something that is really torquey and sounds nasty
Old Apr 6, 2009 | 06:31 AM
rmtt's Avatar
I had Predator-Z spec my cam. Plenty of TQ all the way across, and the car pulls insanely. This is with just a LS6 Intake and 853 heads. In the next 2 weeks, i will be adding heads and a Fast setup.
Old Apr 6, 2009 | 11:09 AM
Zach79Z's Avatar
Some very nice numbers
Old Apr 6, 2009 | 12:14 PM
WeathermanShawn's Avatar
Zach:
228/230 .588/.592 112 +2 LSA..
That is probably not a bad choice for your current application (stock heads).
If chop is what you want, with 5 degrees of overlap you should be happy.
From my experience once you get past ~6 degrees of overlap, you really will not get the full benefits of that additional overlap without steeping up your compression ratio (I.E. heads).
For example I am currently running a 228/232 110+2 on a 62cc head. My Hp peaks at ~6000rpms..but carries to ~6400rpms before slowly falling. But without the additional CR, I am not sure you could carry the power peak to your satisfaction.
A lot of the Torque gains from the higher overlap cams are being aided by a higher CR head and more efficient exhaust ports. On stock heads many are making lots of power with far less overlap.
Just some additional thoughts for you. There is always a 'sweet spot' you have to hit once you start bumping up cam duration/overlap.
Good luck.
..WeathermanShawn..
Old Apr 6, 2009 | 12:44 PM
  #32
beedo's Avatar
This thread has some great info, but I was wondering why stock cams are~ 117-120 LSA and run out of steam at 6000 rmp. From what I have read in all of the cam threads in the last few months that I have tried to figure out what to get is the higher LSA's will put you higher in the RPM range and the lower LSA's get you there with less RPM's. You would think they would pull to 7000k easy with a 121 lsa, LOL. Is it true that the Higher the LSA the easier it is on the idle, especially with an auto trans?
Old Apr 6, 2009 | 01:49 PM
  #33
Beedo:
I use the "DCR Calculator" published by Pat Kelly. If you run a Timing & Overlap calculation on a stock LS1 cam: 119/209 119+4 LSA..
What you get is still a fairly low Intake Valve Closing (IVC) of ~34.5 degrees.
A 228/230 112+2 cam has an IVC of ~44 degrees.
The later IVC's and additional lift from the added duration is why a cam with an IV of 34 will poop out early, and one with 44 degrees will hit 6600 RPM's.
But you are right, there are many ways to manipulate the valve timing events..LSA are overlap are just a piece of a much bigger puzzle.
Hope that clarifies.
..WeathermanShawn..
Old Apr 6, 2009 | 04:27 PM
  #34
Zach79Z's Avatar
Originally Posted by WeathermanShawn
Zach:
Good luck.
..WeathermanShawn..
Not sure if it helps any but i plan on running .40 gasket (PVC allowing) to add a LITTLE compression. Dont think itll add much but thats prolly how it will go. I also plan on adding ported and milled ls6 heads down the road, but for now itll be cam only
Old Apr 7, 2009 | 09:06 AM
  #35
Zach79Z's Avatar
Just got my specs from patrick G
231 231 .617 .617 112 +4
