View Poll Results: which rocker arms?
comp gold 1.7 or 1.8
1
7.69%
comp pro magnum 1.7 or 1.8
1
7.69%
crane gold 1.7 or 1.8
3
23.08%
harland sharp 1.7 or 1.8
8
61.54%
Voters: 13. You may not vote on this poll
which rocker arms?
Old Apr 5, 2009 | 05:14 PM
rjkZ28's Avatar
Default which rocker arms?
hey guys im lookin at getting rocker arms for my car. i have a ms4 cam with stock heads. the car is 02 z28. just wanted to hear what people thought about the comp gold or comp pro magnum, crane golds, or harland sharp?
Old Apr 5, 2009 | 05:16 PM
rjkZ28's Avatar
also should i get adjustable or non adjustable.
Old Apr 5, 2009 | 09:00 PM
'02 WS6's Avatar
If you are dead set on going aftermarket I'd go with non-adjustable Yella Terra Ultralites 1.7
Old Apr 5, 2009 | 11:01 PM
SOMbitch's Avatar
Stockers are better in most apps with OEM style heads. They are are lighter and with the HS upgrade rarely if ever fail. Having said that if I were running an aftermarket bronze guide head I would stongly consider a YT UL rocker.
Old Apr 6, 2009 | 05:25 AM
vettenuts's Avatar
I didn't vote. The two missing from your list are the stocker and the YT UL, which as stated above, would be the first ones I would consider.
Old Apr 6, 2009 | 07:38 AM
theinstag8r's Avatar
I would have them rebuilt by HS.
Old Apr 6, 2009 | 08:30 AM
BYE RICE's Avatar
Stock with Harland bearings.
That's how I roll.
I used to run Com Pro magnum 1.75's...I had no problems until I went with the bigger cam.
The bigger cam didn't like the bigger (1.75 vs 1.70 stock) ratio.
But the guy I sold them to has really good luck with them when run with an XE lobe.
Old May 6, 2009 | 01:10 PM
El_Diablo's Avatar
YT ultra lights here. HS does have some issues with failures. Don't know how common it is but I've heard of them, recently.
Old May 6, 2009 | 01:21 PM
NemeSS's Avatar
sportsman jesels, same price range as all above,
Old May 6, 2009 | 02:19 PM
DVS99TRANS's Avatar
That is what's going in my 408 VERY SHORTLY. They look like they could take one hell of a beating with how thick they are. Everyone I talked to about getting aftermarket rockers told me to go with Yella's if I wasn't going with a shaft mounted set.
Old May 6, 2009 | 02:23 PM
Ericbigmac83's Avatar
Stock ones
