Sowing machine/diesel sound??
I will post an update as soon as i find out what the proper pr lenght i need, if it is that.
im interested to see how your PR length checks out.
i need to go back and check my base circle, but i remember the base circle on the hotcam wasnt as small as what people said aftermarket cams usually are...
how is the PR checking tool work?
jeremy
I went to TXMaro's shop today and had a chance to listen to his car. They sound almost identical. So it's more than likely a combination of the forged bottom end and the pr slack.
Still waiting on the pr checker.
the ticking is more obvious from the wheel well area...
http://www.youtube.com/watch?v=58cJhwpfsoI
as for the pushrod length, ive done some investigating. i pulled all the PRs and they are all perfectly straight. i measured my stock cam's base circle. the weird thing is that if i remember correctly, the hotcam had a 1.520" base circle, while the stock LS6 cam measures 1.495". everything ive read states that the aftermarket cams have smaller base circle. i dont know who makes the hotcam for GM, or if they actually make them. i thought comp made the LT4 hotcam, not sure though.
so, if the base circle is larger, id need shorter PRs right?
now, ive read comp's info on the PR lenght checker. its kinda hard to tell if ive got good geometry or not because there isnt a precise point of contact like a roller rocker has, but the geometry looks pretty good to me with the stock PRs. what do you guys think???
dont mean to highjack the thread, but its i figure we could make this a group thing....
Jeremy
i'll know for sure when i replace or have my heads ported. ill throw some LS7 lifters in while im in there and see how she sounds after that. it will be a while till i do that...
Is the PR length checker the absolute way to know for sure .... yes absolutely however i trust their advise since this is what they do. Like i said if they questioned it .... so should you. If not i have faith that they know what they are doing.
