Sowing machine/diesel sound??
Is anyone running these pistons with similar probs??
The quicker lift cam lobes of your cam + high pressure springs are noisier than stock so that is prolly your issue...
Did you check your PR length with a checker......If not do so.....
It did have the knock before the cam swap. And its louder when cold, but gets slightly quieter when hot. But it is still there all the time.
Took it to about 4 mechanics, 2 said lifters, 1 said pushrods, and 1 said rockers (but he didn't really look into it).
After that I knew it wasn't piston slap.
I'm going ot go compare it to TxMaro and see what the difference is..
I had a MTI X1 cam and those were the pr's they were using on that cam, and it still made the same noise?
