how does everyone install there ARP studs?
Old Apr 9, 2009 | 12:44 PM
Taubr Unit's Avatar
Default how does everyone install there ARP studs?
When threading them into the block do u use moly lube or threadlock them in??
Old Apr 9, 2009 | 01:00 PM
Randy WS6's Avatar
I use the red loctite , I screw the stud all the way down and back it off a haft turn, Then i use the molly lub for the nuts to set the torque
Old Apr 9, 2009 | 02:09 PM
Taubr Unit's Avatar
Ok. That's what I heard but didn't know if id be able to get them out easy down the road.
Old Apr 9, 2009 | 03:03 PM
1CAMWNDR's Avatar
I just finger tighten the stud.
Old Apr 9, 2009 | 03:07 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Finger tight on the stud into a clean hole. Carrol Smith recommends Red Loctite, but still only finger tight. Moly lube on the exposed end.
Old Apr 9, 2009 | 03:14 PM
Taubr Unit's Avatar
everyone says finger tight but only but seems like a few i seen they never go all the way in with just your fingers. always needed to use a allan to get them all the way down.
Old Apr 9, 2009 | 04:18 PM
MeentSS02's Avatar
Probably because the threads aren't clean.
