New upgrades
Patriot Stg 2 LS6 heads/ 220/230 .585/.585 112lsa
Dual Timing set
Pacesetters with ORY and SLP dual dual
Ported/Descreened MAF
I'm want to add these parts.
LS6 intake w PP TB and 42lb injectors
25%ud
LS6 oilpump.
HS 1.8 RR
Are these a good mix of parts for my combo?
I'm hoping to get 440-450rwhp...
And call texas speed about porting a ls6 oil pump. I dont know if they will but i think they port the oil pumps they sell so maybe they can hook ya up with some porting. if not just buy one from em lol
www.sdparts.com
spend the $400 elsewhere
i'd put it into a FAST intake personally...while its all apart you might as well go for broke.
should make 440-450rwhp with the setup if you port the FAST and get a good tune.
Its got a 224 cam, a fast intake, nitrous, and ported 243s on it
Then you would say, well id put a fast on it.
COME ON. He didnt ask about a fast. He asked about the rockers. What makes you think that cam is so aggressive that it would hurt to put those rockers on? Wait, to even think about putting the rockers on? He was told to be wary of lift. If it has too much lift, then he should not, but if he can work with the higher lift, is there a reason to say no? And dont pull the BS excuse of rocker arm tip weight or moment of inertia or any of the other fabled power losses/parasitic losses that he could exp.
and i figured with heads and the decent cam he listed....he could take the $$ from the LS6 intake purchase and the $400 saved by not doing rockers and he'd have a pretty good chunk of the cost of a FAST...even new.
as for rockers...
here is a clip from TR's website....for a significantly smaller cam than he listed:
Thunder Racing Custom Camshaft
"TR 220-112" - 220/220 .551/.551 112 LSA 1500-6500 RPM Power Band. Computer Tuning Required with automatic transmission cars. A very well balanced camshaft that makes excellent power across the entire RPM range. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended."
the cam he listed look like XER lobes...which are too aggressive for 1.8 rockers.
its more than a matter of lift and whether springs can handle it.
you could probably do it, but it wouldn't be the most reliable thing to run. and with .620" lift he could run into PTV clearance issues, depending on heads, valves, and head gasket.
dont know anything about the ls7s, but my guess is they are different enough to handle the change.
and when one of the top LSx shops in the country doesn't reccomend something...in general i listen.
BUT...you're obviously an internet BADASS....so maybe i should bow down and kiss the ground you walk on
It is your build, so do what you want.
LS6intake- as long as a win the auction.
PPTB / 42lb injectors
25%UD pulley on the way. These should help reach my motors potential for now.
Also got a panhard bar, SFC, and LCA's so I should see a noticable difference!
