Whats above the oil filter
Old Apr 10, 2009 | 03:44 AM
jamiesls1's Avatar
Default Whats above the oil filter
Above my oil filter is this little I am guessing hole for something. I am not sure what it is for or if it needs to be plugged up. Thanks
Old Apr 10, 2009 | 03:53 AM
wadelieck's Avatar
um if you dont know what it is i would no go plugging it up and there is no whole that need to be plugged up man.
Old Apr 10, 2009 | 03:55 AM
wadelieck's Avatar
and is it on the oil filter its self or are you talkin about on the block
Old Apr 10, 2009 | 05:23 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
It is a block off plate on the F cars, the Vettes have an oil temp sensor threaded into the top of it
Old Apr 10, 2009 | 02:10 PM
jamiesls1's Avatar
Sweet, thanks guys!
Old Apr 10, 2009 | 07:48 PM
bigdsz's Avatar
Behind that little manifold are two oil gallery holes that can be used for an oil cooler. Lingenfelter has a cnc machined block available to install a cooler.
