Increase in power from milling heads?
Old Apr 10, 2009 | 07:09 AM
Vcious04's Avatar
Default Increase in power from milling heads?
I would like to see what kind of gains folks have achieved with milling heads. I know alot of variables come in factor, maybe a before and after?
Old Apr 10, 2009 | 07:34 AM
vettett15's Avatar
I can tell you that adding TSP Stage 1 LS6 heads milled to 59cc and a LS6 intake and a 25% UDP I went from 370 to 440. I have 300 ft*lbf at 2250rpm. That is going from stock 98 heads and whatever compression ratio stock is to about 11.4:1.
Old Apr 10, 2009 | 10:35 AM
PREDATOR-Z's Avatar
Ever 1 point in compression increase is worth about 3>4% more power.
So if baseline is 300rwhp at 10:1, the same motor at 11:1 should make ~312 rwhp
Old Apr 10, 2009 | 10:52 AM
litle88's Avatar
Before- Gm hotcam, 241 heads, fast 90, Harland 1.8's stock compression.
After- Trickflow 220's milled to 60cc's, VRX5 cam, Harland 1.7's 457hp and 405ft lbs
Old Apr 10, 2009 | 11:09 AM
teke184's Avatar
not sure how that helps...
different heads, different cam
Old Apr 10, 2009 | 11:43 AM
bigboykilroy's Avatar
Litle88 what is the specs on your VRX5 Cam?
Old Apr 10, 2009 | 06:10 PM
PREDATOR-Z's Avatar
Originally Posted by bigboykilroy
litle88 what is the specs on your vrx5 cam?
236/238 .601/.605 113 lsa
