Head gasket thickness
Old Apr 10, 2009 | 06:49 PM
firemech21's Avatar
Default Head gasket thickness
I was just talking to a guy who builds race engines about my LS1. He said you could gain up to 20hp by getting thinner head gaskets, does anyone know how thick the stock head gasket is and where you could find thinner ones at?
Old Apr 10, 2009 | 07:06 PM
smask04C5's Avatar
All of the gaskets that I remove and remember to mic, are .052-.054. Cometic makes gaskets thinner than you could run on the street with a stock rotating assembly. Cometic LS-1 head gasket 3.910, with a .040 thickness is a great choice, but no guess as to how much power it would add. Decreased quench and the possibility to add ignition timing increase the output.
Old Apr 10, 2009 | 10:15 PM
zeekracing's Avatar
a thinner head gasket will raise your compression a little bit but you won't hardly notice any gain from it. Maybe a few horesepower but not 20hp.
Old Apr 10, 2009 | 11:12 PM
SOMbitch's Avatar
With the right setup the .040's give better quench and not only increased compression but allows for more timing to be safely run....due to the improved quench...
Old Apr 10, 2009 | 11:36 PM
KCS's Avatar
KCS
Moderator
Don't forget the thinner the gasket, the closer the piston gets to the cylinder head. LSx engines are already ~.007 out of the hole.
Old Oct 8, 2012 | 09:11 AM
bufmatmuslepants's Avatar
Bringing this back from the dead, but my friend has a burnt exhaust valve or something causing only 100psi in one cylinder of his 60k mile bone stock 03 vette, we are pulling the heads to look at it. In the LT world where I am from we use the 0.026" mr gaskets to bump compression to 11.1:1 with a stock longblock, is the 0.040 Cometics the best replacement for an LS motor? Or should we go with a stock replacement?
Old Oct 8, 2012 | 10:54 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We need to know how far your piston are in or out of the hole to make the call, as well as piston and head volume!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 8, 2012 | 12:07 PM
slt200mph's Avatar
Do not bother to run skinny head gaskets for a HP gain. Not enough of a change to make any significant increase in HP. If you want real high compression. Mill the heads down to 59cc chamber and run the Cometic .040 gaskets. That will get you the 20 HP bump your looking for.
Old Oct 8, 2012 | 12:34 PM
This is just going to be a "saturday, get it fixed" deal. The motor is dead bone stock, never touched, which makes me curious to think an exhaust valve would be jacked up. He said he has 100psi on that cylinder, and 160 on the rest, and if he puts a paper towel on one tip it will get sucked in a little. Originally was thinking a misfire. If no point to add compression then well will just use the Summit kit for swapping head gaskets, and just do the one head.
Old Oct 1, 2022 | 06:17 PM
Bdh29's Avatar
Old Oct 1, 2022 | 06:19 PM
Bdh29's Avatar
I don't know who you are or where you're at, but........YUT KILL!
Old Oct 1, 2022 | 10:50 PM
So 10 years since the last post in this thread, you put this useless garbage up for all to see, and you even mess up the first of your 2 posts in the process??
Quit wasting your and our time.....
Old Oct 2, 2022 | 02:48 AM
grubinski's Avatar
Maybe Corona is back. :-)
Old Oct 2, 2022 | 09:41 AM
You never know for sure, but it looks like this genius joined back in 2013.
Old Oct 2, 2022 | 01:38 PM
Not yet. And when he does pop back up, he’s gone first post. No more BS around here. MTGA!
Old Oct 2, 2022 | 03:02 PM
LilJayV10's Avatar
Does that mean he left?
If so I might start reading more threads.
Old Oct 2, 2022 | 03:46 PM
He has left the building. Read up! Heck, didn’t take long before some of our sponsors came back in and starting posting again.
Old Oct 3, 2022 | 03:45 PM
Bdh29's Avatar
Phew - for a second there I thought you were going to try to be a tough guy by being a petulant *** to a complete stranger for not understanding his Marine reference, getting phased out at work, and because your wife always smells like someone else's cologne.
That was a close one!
Old Oct 3, 2022 | 04:03 PM
Nope. Just don't get into obscure references aimed at those not here for ages....
Old Oct 3, 2022 | 06:54 PM
grinder11's Avatar
