Swapping heads and cam..With pics!!
Old Apr 14, 2009 | 02:28 PM
LS1-NAVY's Avatar
good work man, i like all the pics
Old Apr 14, 2009 | 02:58 PM
BobDoLe's Avatar
Originally Posted by nalmak
I honestly dont know...Im guessing scarring from being to lean??..It looks as if it was melted a bit..Like i said the previous owner sprayed it..Im guessing untuned..But oh well..Il replace it when the crank sticks out of my block..
Ill post pics of the pass heads tomm..Its very lean
it looks like the nitrous just cleaned the carbon deposits off the pistons, but its hard to tell with the photo quality.
Old Apr 14, 2009 | 03:43 PM
TooLateVTEC's Avatar
Looks like fun.
What cam did you stick in there?
Good luck on getting it back together quick !
Old Apr 14, 2009 | 04:17 PM
nalmak's Avatar
ok got the front cover onSwapping heads and cam..With pics!!-front-button.jpeg..and the new gasket..thanks shane (LS1W)...
New lifters and ls2 lifter tray's went in.Swapping heads and cam..With pics!!-ls2-tray.jpeg
the cam went in pretty smooth..just keep turning it...
ran into problem..trying to put on the balancer with the ols bolt
it dosent seem to catch the threads..but when i use my 1' longer crank bolt..i get it.
so could i force the balancer on the crank more so the old bolt can catch the threads?
Old Apr 14, 2009 | 05:15 PM
bigboykilroy's Avatar
You can put it on by hand at put a block of wood at the front and tap it on a bit, then use your old bolt to out it on.
Old Apr 16, 2009 | 11:13 PM
joecar's Avatar
Thanks for the pics...
Old Apr 17, 2009 | 01:06 PM
nalmak's Avatar
sorry guys i had a delay..it seems i got the wrong head bolts from APR..I got the gen 4 head bolts and not Gen3.. so any way now its starting to look like a car and not a pile of crap..
so if anyone needs a gen 4 head bolt set..get mines for $60 instead of $105..never torqued down just greased up
now for some new pics
Rockers Installed
Now it looks official
Money Shot
Old Apr 18, 2009 | 11:10 AM
nalmak's Avatar
Ok ran into a problem..Since the person that did my exhaust welded the collector to the pipe..Its very hard to get the headers on..AND I had to break the hangar loose to remove the heads and push the header out of the way
Any ideas on how to bolt the header on..The pass side didnt break loose so it bolted back up..The driver side is the problem..Since the whole pipe is laying on the floor???
Old Apr 22, 2009 | 10:02 AM
nalmak's Avatar
Lol..Ive been posting everywhere but here..
ran into a heap of problems..But got it fixed and willpost once it fires up
Old Apr 22, 2009 | 10:25 AM
Well atleast you got it figured out !
Get it running yet?
What camshaft did you put in it?
