cam motion lobes vs. comp lobes???
my question is how are the cam motion lobes compared to the comp as far as performance, the reason I ask is because I know little about the company and just wondered if anyone else on here has compared the two, or could give me an input on both.
thanks
Cam Motion has always given me better driveability, and on average, more power. May not be this way for every shop, but it has been for me. You'll find some people won't use them because Cam Motion had a problem a while back with cams falling apart, but have since fixed the issue. I, FWIW, have never had a cam issue and I've used probably 10 of their cams in the past 2 years.
I was running a TR 230 236 600",600" on a 112+2 before, and that was on comp lobes xfi if I am not mistaking. I will definatly reply back once the car is up and running with results from the old to new setup
it will be bias however because i upgraded to a vengeance ported fast 90 from my old ls6 intake and added bigger injectors and a 410 gear from a 390
either way it will be interesting to see
Check out the video in my sig. Full weight (3600lbs raceweight) stock bottom end H/C/I stalled 2002 Camaro..
