anyone running the GMPP ASA, or Stage 2 cam???
im just thinking about eventually pulling my hotcam and going with something like the ASA or the stage 2.
would the stage 2 be very drivable with a M6? 108 lsa is pretty close isnt it? would it have a really choppy idle?
and what kinda HP would i be looking at with worked 243 heads and a 78mm TB?
thanks,
Jeremy
thanks,
Jeremy
Haven't seen anyone run the Stage 2 cam yet, but there are plenty of threads on the ASA. I put down 393rwhp cam only w/ my ASA. Just added a set of GMPP LS6 heads, but no #'s from that yet.
LS1TECH & Trucks Sponsor
The stage 2 should be fairly tunable for great driveability. Getting into that GM cams really just gets you into the area where you should just get an aftermarket cam. It would, however sound incredible at idle with it's wide split and tight LSA. It's just not a cam I'd really ever recommend, cause anyone wanting something that range should just go aftermarket with a cam tailored to their needs.
Alot of people love the ASA cam.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
id like to know what that asa would have given me if you didnt even have the 243 heads and got 393! sounds like that would be a rippin cam with a 78mm tb and some head work for my V!!!!
