%#&! (not happy)
Old Apr 16, 2009 | 03:29 PM
OUTLAWZ RACING's Avatar
Hell Yeah Good luck, I feel your pain I daly drive my Z also. But that 370 should rock harder than the 347 and its alum so you save on weight. Oh I have heard that the pcv lines can fill with water sometimes if they are dry rotted.
Old Apr 16, 2009 | 03:49 PM
bjamick's Avatar
What is the bore and stroke on an LQ4?
Old Apr 16, 2009 | 03:52 PM
zakk101WS6's Avatar
Turns out, its an Iron block. Still good with me. Up untill this time I ran a breather on each cover. I just put on a rev-xtreme catch can the day before I started it. Never even got a chance to even run it with the can system.
Old Apr 16, 2009 | 04:01 PM
brandotron's Avatar
Damn dude, that's a heart breaker. Glad to hear everything is working out for you--and you're handling it like a champ!
Old Apr 16, 2009 | 04:02 PM
zakk101WS6's Avatar
Stroke is the same as an LS1 I believe, not sure about the bore , 4.000?
Old Apr 16, 2009 | 04:03 PM
zakk101WS6's Avatar
Haha, thanks broseph! Hopefully it all works out. It's out of my hands now...
Old Apr 16, 2009 | 05:33 PM
bjamick's Avatar
Ok I was just wondering bc everyone was saying put your rotating assembly into a 6.0 block, but you will need to buy pistons that fit the hole. 4" is prob what it is.
I feel for you man. Glad your taking it well but atleast alot of your parts are still good.
Old Apr 16, 2009 | 07:44 PM
4.002 I think but yeah pistons and rods stock crank and spray it lol! He is still in the game with mahale pistons and egal rods summit has them in stock.
Old Apr 16, 2009 | 08:55 PM
zakk101WS6's Avatar
Yea, TSP has some good stuff in stock. Diamond and Wesco. It's tempting, but I think with me separating from the service here in the next month and becoming jobless it would be smart to stay budget for now. In addition, its the worst possible timing as far as where it happened. Stock internals will be more than enough for now. I will get my rod bolts transfered over to the LQ9 (just found out it wasn't an LQ4) , along with the oil pump and pan and everything else on the top end. I just hope that we can figure out what caused this crap to happen. Hopefully it was just a head gasket (which would make this my fault). Anyway, I'm still in the game
Old Apr 17, 2009 | 03:10 AM
PREDATOR-Z's Avatar
Just make sure they measure PTVC, LQ9 is flat top slugs and has no valve reliefs. (better than LQ4).
BTW, no need to tap for a third alternator hole, I have a 370ci and never did that. no issues.
It should make good power with that combo.
Old Apr 17, 2009 | 03:14 AM
zakk101WS6's Avatar
Yea, we are most likely going to be fly cutting.
Good to know about the alternator! Thanks for the info bro.
Old Apr 17, 2009 | 03:33 AM
  #32
PREDATOR-Z's Avatar
Are your heads milled? If not you might get by without flycutting using stock MLS 6.0 gasket.
Let them measure clearance first and make your decision. It is always better to keep the pistons unmolested if you can.
Old Apr 17, 2009 | 03:39 AM
  #33
zakk101WS6's Avatar
They are not milled. They are untouched from TSP.
Old Apr 17, 2009 | 04:17 AM
  #34
PREDATOR-Z's Avatar
Good, If they have 2.02 valves, you won't need flycutting. Still measure nonetheless.
If you can get the shop to degree the cam, you'll benefit from that. TV3 is a real good trq grind provided it is at said ICL. Sometimes the grind is off a bit. (true for any cam)
Old Apr 17, 2009 | 06:47 AM
  #35
05gto60's Avatar
you do know you can claim unemployment from any state you want right? long story, but ive been getting CA unemployment since sept 07. its not a ton, but at $450 a week, its pretty nice
Old Apr 17, 2009 | 07:33 AM
  #36
zakk101WS6's Avatar
PM'd!! Thats a pretty sweet, plus the new GI bill I would be making almost as much now as an E5.
Old Apr 17, 2009 | 01:39 PM
  #37
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Welcome to the Florida hydrolock club. The engine in my Formula did the exact same thing on 6/3/07, right around 3 months after I bought it. I have pictures in the formula build thread link in my sig on the first page.
I'm pretty sure that is what happened to mine. The line runs perfectly down hill and when I tore part of it apart I noticed that.
Old Apr 18, 2009 | 01:51 PM
  #38
zakk101WS6's Avatar
Here are a few pics of the damage....
Dayum!!
Old Apr 18, 2009 | 02:04 PM
  #39
AutomagicLS1's Avatar
Hrmmmm. IMO I dont think it hydrolocked......
Old Apr 18, 2009 | 02:32 PM
  #40
Benjamin Russick's Avatar
Wow! That's some serious carnage!
