Getting a cam got some ?'s
Old Apr 16, 2009 | 08:32 PM
blueghost6789's Avatar
Default Getting a cam got some ?'s
I tried searching but I dont always find the anwsers I neeed.
I am buying a cam for my car I was wondering what I needed
Also any recamondations would be nice I drive the car about 5000 miles a year I want to get the most power I can and dont care about idle too much and I have a 4 cyl for gas mileage. This is what I was thinking let me know what I need to add or subtracrt
99 LS1 Firebird
Texas Speed magic stick V.4
LSA 110
Comp PRC Spring Kit, and
Hardened Chromoly Pushrods
7.4
GM Replacement LS7 Lifters
GM Gasket and bolt Kit
In Motion LS1 Double-Roller Timing Set
Oil Pump ????????????
Then a tune
Also how much should an install cost
I rather spend to do it right the first time sorry for my grammer and trying to search I dont have a lot of time
Old Apr 16, 2009 | 08:54 PM
JDishong's Avatar
Do you have automatic or a stick? If auto - do you have a stall convertor? You will need one with that cam.
Old Apr 16, 2009 | 09:17 PM
Zach79Z's Avatar
Well the kit you got looks good but id go with a ls2 timingchain instead of the double roller and id go with a ported and shimmed ls6 oil pump from texas speed. Also where are you located? If you are close to a sponsor on this board id let them do it.
Old Apr 16, 2009 | 09:30 PM
1SLwLS1's Avatar
I am curious as to why you are lowering the LSA from the standard 111? I have no clue about these LS marvels
