I'm fixing to do a tsp torker 3 cam should i change oil pump?
Old 04-16-2009, 11:18 PM
ls1 dude's Avatar
Default I'm fixing to do a tsp torker 3 cam should i change oil pump?
i am fixing to do a cam swap on my 2002 ls1 with 34,000 miles. i am going with the tsp torker v-3 cam kit do i need to change my oil pump?
Old 04-16-2009, 11:44 PM
LSX Mechanic
Damian's Avatar
You'll be fine with the stock pump being an 02 with that low of mileage.
I would however, replace the timing chain.
Old 04-16-2009, 11:45 PM
sunsetorang01TA's Avatar
You can swap to a ported oil pump if you'd like. It isn't required though. I didn't do it on mine. ported oil pumps are about 150 dollars and they just offer alittle more flow and cooling.
Quick Reply: I'm fixing to do a tsp torker 3 cam should i change oil pump?
