How long will an LS! last?
Old Apr 18, 2009 | 10:17 PM
Zaxz28's Avatar
Default How long will an LS! last?
I have an opportunity to pick up a 99 corvette for relatively cheap, about 10 grand. It is a little rough, a lot of the work I can do myself. (oil sensor, a lot of cleaning) However the engine has 93,000 on it. I don't have a lot of money, and I would like to do the little things to it, Air intake cat back ect as time goes by. The engine does not blow any smoke or use any oil. I know it depends on how it was driven, but there has to be some kind of average. How long can I expect the internals of an LS1 to last? Is this car getting to a point where things are going to start breaking? Thank you for your advice.
Old Apr 18, 2009 | 10:20 PM
bene's Avatar
Trunion King
They last forever as long as you don't hydrolock them.
Old Apr 18, 2009 | 10:21 PM
Zaxz28's Avatar
how many on your camaro?
Old Apr 18, 2009 | 10:27 PM
bene's Avatar
Trunion King
111K miles.
Old Apr 18, 2009 | 10:29 PM
ProjectDuStU's Avatar
Every car is different.. to say it will last 300,000 miles or 100,000 is wrong both ways.. car usually last dependent on the owner and how they are taken car of. If the outside of the car is trashed and needs tlc how do you think the previous owner took care of the motor?? My motor lasted to 160k and that was beating the hell out of it, racing at the track, street and numerous daily trips to 7000 rpm.. that was with a stock shortblock, just cam and bolt-ons.. its all realative. They are known to be a longer lasting motor but usually its a rod bearing or main that does them in.
Old Apr 18, 2009 | 10:34 PM
2002 SS HUGG's Avatar
In theory, the LS1 was the start of a stout line of LS engines GM produced. I believe the LS1's are tough motors and take tremendous amounts of abuse. If a car has 93,000 miles this decision is not up to me, but you. If you want to keep the block...I'd start with freshening up the valvetrain; maybe some new pushrods, valvesprings and retainers (TSP PRC Dual Spring Kit), replacement lifters (LS1 or LS7), maybe rockers re-done by harland sharp if you don't wanna spend 400 on new aftermarket ones, LS6 pump, LS6 intake, new spark plugs, MSD spark plug wires, new timing chain, water pump and maybe some new gaskets and bearings. Other than these things...I think you'd be pretty safe. All in all, I don't think you have to worry to much about the internals as much as you do valvetrain wear.
Oh yeah, has the car been moded at all? If it hasn't, then I'd say you're pretty safe because teh stock rev limiter is set at 6200 I believe and these engines rev up to 7k no problem on stock internals.
Old Apr 18, 2009 | 10:40 PM
95BLKMAX's Avatar
Mine is an 02 SS with 88k on the clock. I bought it off my brother-in-law so I know that for the last 55k+ mi that he had it, he drove it nicely and it always had 5W-30 Synthetic oils. I run the same, and I dyno'd recently at 325WHP/ 335WTQ (SAE) with just the free ram air mod and K&N filter. Motor runs great and smooth, does not leak or burn oil.
Old Apr 19, 2009 | 01:31 AM
DesertFox's Avatar
Don't be afraid. I have 158k and no worries. It will run 13.3's at the track all day too (lid, cat back, and tires only). If the motor has been taken care of it will be fine, I would worry more about the trans than the motor, I had to rebuild mine at 120k.
Josh
Old Apr 19, 2009 | 10:05 AM
Z28SteveA4's Avatar
my friend has one with over 180,000 and hes running 12.5's with over 60 passes just this year alone. Believe me they are strong motor. Dont be afraid
Old Apr 19, 2009 | 11:12 AM
01FbTaWs6's Avatar
lets just say there is people camming there cars at 180k. Its dependant on how the car was taken care of. Mine has 106k on it and i beat the living snot out of it every chance I get. But I take care of it and fix anything that might start to go wrong. Its all dependant on the previous owners care.
Old Apr 19, 2009 | 11:17 AM
99blancoSS's Avatar
How long it will last depends on how it was treated. My 99 engine lasted 84k miles Good oil was used anc changed regularly I drove it hard), heads and cam combo and hard driving took it out. There are some with over 200,000 and some guys spin a bearing at 38,000. Longevity is all dependant on how it was and is treated. Also IIRC the 99's had some oil pump failures and it was recommned to change them at 100k. Do some searching on that, my memory could wrong on that.
Old Apr 19, 2009 | 11:38 AM
Zaxz28's Avatar
Thank you all for your help. The corvette was picked up by my brother about 6 years ago with 73000 miles on it, my dad took it over and drives it on occasion. He has a 69 427 that is his passion. Well the 99 just sits under a tree and collects bird droppings, I try and clean it every couple of weeks. The transmission was repaired under warranty, I don't know to what extent, but it shifts beautifully. He also had to have the headlightswitch replaced in the interior. That was 600 bucks by itself! We were thinking about swapping cars plus a little cash. (81 vette and a thousand or two).
Thank you all again
Zach
Old Apr 19, 2009 | 01:37 PM
DaveX's Avatar
If your brother and father put the last 20k on it and it doesn't use much oil, has good oil pressure, and is quiet (other than the typical valvetrain ticking), I wouldn't be afraid of it at all.
Old Apr 19, 2009 | 02:13 PM
dre2013's Avatar
mine just turned 140k last week, and i am about to have heads/cam installed. i'm pretty easy on the car since it is my DD, but it sees its fair share of beatings
Old Apr 19, 2009 | 02:39 PM
Jeff Smith's Avatar
I just got '00 Camaro Ls1, run +200K milesuzzling:. Motor looks fine but little rough idle and bad greasy/dust on. I ll put Seafoam to clean up at all (vaccum,oil,fuel).
If i have pix, I ll post at speedometer/miles....
Motor >>
Old Apr 19, 2009 | 04:10 PM
Zaxz28's Avatar
I know it isn't the forum, but what about the other accessories, AC PS alternator ect.
Old Apr 19, 2009 | 04:12 PM
Zaxz28's Avatar
I want to know what ls1 owner would let an engine get that dirty
Old Apr 19, 2009 | 09:31 PM
dc8fixer's Avatar
Mine 99 is bone stock and still starts instantly and runs awesome. No smoke and just a very small oil leak. I'm waiting for it to blow up, but it shows no signs of that soon. I sold my last one with around 171,000 and it ran the same.
Old Apr 19, 2009 | 09:37 PM
BigRobSS's Avatar
Originally Posted by dc8fixer
mine 99 is bone stock and still starts instantly and runs awesome. No smoke and just a very small oil leak. I'm waiting for it to blow up, but it shows no signs of that soon. I sold my last one with around 171,000 and it ran the same.
that is impressive!
Old Apr 19, 2009 | 09:43 PM
7camaro7's Avatar
Motor >>
you might want to put your air lid on right too before that rough idle gets worse!
