If the ASA cam makes good torque
A buddy of mine ran this cam for a while, the car felt SICK on the street and he pulled on plenty of 420+ rwhp LS1's. His car made a best of 409 rwhp peak, however his area under the curve was to this day the best I have ever seen on a 346 hydraulic car. This was all with a set of POS heads that only flowed 260 cfm. With some better heads, that car would have made 430+ rwhp and prob. 420+ TQ.
It's a good cam, get your car tuned by someone who knows what they're doing, and you'll like it a lot.
Josh
I would NOT recommend a mail order tune for this cam. I needs to be on a dyno, and tuned properly.
Josh
Josh
Josh
Here's the quote from Jim Hick's (LS6 Camshaft Engineer):
What about that ASA cam? It’s got only .525-in. lift but, at .050-in., it’s got 226° intake duration and 5.5° overlap versus the LS6’s 204° and no overlap. Clearly, it’s designed for higher rpm and more power but it needs a very low restriction or open exhaust. Will it work in a hi-po street LS6? Well–kinda sorta. Once you get the cam and the right valve train pieces, the biggest problem comes if you have to remain emissions legal. Getting the engine to run with the ASA cam but without the OBD2 diagnostics blowing codes would be a challenge you have to tackle–but only after you design a cat converter set-up and exhaust system that has low enough back pressure such that the ASA cam’s potential can be realized.
Josh
Did you ever install the setup or did you sell it? Shoot me a PM man.
There are some tricks to assure the proper setup in the hotcams from what I have found. Buy asking a GM powertrain rep I have be told the to use 1.8 rockers on the cams to get full desighn of the profile.
I guess they are spec. for .555" to take full advantage of the stock head and intake flow. Who am I to argue with GM.
But know complaints here with the hotcams. I mean I have seen (been in the car) when a 420+rwhp H/C M6 car could not pull a bolt-on ASA A4 with stock heads.
And as for drag racing well the ASA gained a new best for his car even when launching in 2nd gear. ( still trying to figure this one out) So needless to say the ASA WILL work for dragracing. When the season opens again we should see 11 sec passes out of it with no weight reduction.
hotcam'ed and happy,
Mike
Dam you dame maybe I should ban you from my pc
-Corey
-Corey
