If the ASA cam makes good torque
440 hp @ 6100 rpm
427lb-ft torque @ 4850 rpm
GM ASA/SCCA LS1 camshaft, part number 12480110
LS1 "853" casting cylinder head, center bolt valve cover
LS6 Valve springs
LS1 Intake manifold
mechanical throttle body
heavy duty A1 rod bolts
ATI Super dampener
Turn One power steering pump
cast aluminum ARE dry sump oil pan
Razor two stage oil scavenge pump
I like the cam,it make TQ and has a good area under the curve...
440 hp @ 6100 rpm
LS6 Valve springs
LS1 Intake manifold
ATI Super dampener
Was that an engine or chassis dyno?
