Seafoam WTF?????
Old Apr 20, 2009 | 09:36 PM
firemech21's Avatar
Default Seafoam WTF?????
I just ran seafoam through my 99 T/A, it took out both my O2 sensors. Has this happened to anyone else. When i first started my car up after letting it set for 5 minutes it gave out a small puff of smoke then nothing. I took it for a test drive and it worked fine. Then after driving it for about 20 minutes the SES light popped on with the O2 sensor codes. Can i fix this somehow?
Old Apr 20, 2009 | 09:37 PM
1SLwLS1's Avatar
yea, just clear it and drive it through a few heat cycles, its fine.
Old Apr 20, 2009 | 09:46 PM
01ssreda4's Avatar
i have had it take out spark plugs on several vehicles that i have used it on. camaro so far is still running good though.
Old Apr 20, 2009 | 10:56 PM
Damian's Avatar
LSX Mechanic
Give it a little while and it should clear up.
I usually only seafoam an engine right before a plug change/oil change. Once it's ran through and done smoking, I immediately shut it down and change the oil. Changing the plugs is probably me just being ****, but it's $18 and 20 minutes so it's worth not having to worry about it later.
Old Apr 21, 2009 | 01:35 AM
NAAllTheWay's Avatar
seafoam claims they are 02 friendly....so should be okay
Old Apr 21, 2009 | 10:26 AM
Sigforty's Avatar
Could be other reasons, How old are the sensors, do you have headers, ect? Maybe the carbon build up is that bad. I have had O2 codes before, but not because of Seafoam there were already other reasons.
Old Apr 21, 2009 | 10:59 AM
1994Z28Lt1's Avatar
seafoam is O2 friendly but sometimes the crud that busts loose from treating the engine isn't so friendly
what i always do is run a good dose of seafoam through a couple tanks of gas before doing the actual treatment through the intake, running it through a couple tanks of gas will clean a lot more than you think it will
Old Apr 21, 2009 | 02:15 PM
NemeSS's Avatar
when it does clear up the diff. will be noticeable, esp if the engine had a hi level of gunk and carbon buildup
Old Apr 21, 2009 | 02:31 PM
firemech21's Avatar
When i started it up it didnt smoke hardly at all. It would be like a puff on a smoke. But other than that no smoke came out. I am trying to pull all the O2 sensors out and clean them after that i am going to see what happens.
Old Apr 21, 2009 | 02:59 PM
David_viny's Avatar
Do you have catalytic converters on your car? I noticed at least with my truck which doesn't have cats it barely smoked, but my car smoked a ton and it has cats.
Old Apr 21, 2009 | 03:57 PM
Black Sunshine/ 00SS's Avatar
Either way, you have to change the o2's now.. Change them, keep the old one, so that if you ever do a seafoam again, you can throw in the old ones...
Typical to change plugs, oil, and 02's after Seafoam. Just to cover all bases.
