I need camshaft selection help..
1978 Malibu 3200lbs w/driver, stock style suspension
Ford 9" w/ 3.70 gears
Powerglide w/brake
3200 stall (am willing to buy a new stall up to 4500-5000)
Stock LQ4 bottom end w/ arp rod bolts, lingenfelter oil pump
Patriot stage 3 243 heads w/ .650lift Patriot gold dual springs
Edelbrock Vic JR w/ Accufab 4500 throttle body on Wilson 4500-4150 adapter
1 7/8" Long tube headers
175-225hp Nitrous through a wilson spray bar plate
I am hoping to hit at least a 5.99 in the 1/8th which may or may not be possible with the stock bottom end. I will see I guess.
Give us a call if we can be of help!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
