Went to the Dyno with MS4
Old Apr 24, 2009 | 12:43 PM
litemup's Avatar
Default Went to the Dyno with MS4
Went to the dyno last night with the mods in my sig and put down 410hp and 375tq. Driveability is perfect i could easily daily drive with this cam. No bucking or surging at all. When i was there tho my throttle cable wasnt opening the throttle blade all the way so i gotta figure that out and go back and see if we can pull any more horsepower out of her. I will post a graph after a while
Old Apr 24, 2009 | 12:50 PM
First Collision's Avatar
Not bad.. congrats.
Old Apr 24, 2009 | 12:54 PM
98mysticZ's Avatar
not bad i did 396/381 with the ms4 and a stock 120k 98 ls1 (806 heads, ls1intake)
Old Apr 24, 2009 | 12:55 PM
teke184's Avatar
how much porting is done on your heads. must be just a light touch up.
good numbers though
Old Apr 24, 2009 | 01:14 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Let's see the graph! A FAST intake and a different catback could feasibly net you an additional 25+rwhp!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
litemup's Avatar
the port job looked really good, im hoping when i go back i can pull out some more hp. Im happy with it tho with the driveability and it pulls like a freight train after 3k i love it.
Old Apr 24, 2009 | 01:15 PM
litemup's Avatar
i tuned it with the cutout open i would like to get a fast setup tho.
Old Apr 24, 2009 | 01:52 PM
00Camary's Avatar
Wont he grab more HP with simply getting a set of cheap take off 243's? More so than the FAST?
Old Apr 24, 2009 | 01:56 PM
Similar power between the two IMO. The FAST is an easier/quicker install though and can be carried over if/when he gets different heads down the road
__________________
Old Apr 24, 2009 | 02:06 PM
teke184's Avatar
ported 241 are probably gonna outflow a set of unported 243s.
and he's already GOT the ported 241s....
with a smaller cam, and stock heads i gained 18hp with my ported FAST. so i would think at least 20hp would be possible with his setup.
would def be the next logical step
Old Apr 24, 2009 | 02:17 PM
litemup's Avatar
these heads will be on here for a while until i can afford those new heads tsp came out with that they have on there record setting stock bottom end heads cam car. So the fast will be the next thing i will get down the road until i get those heads.
Old Apr 24, 2009 | 02:18 PM
litemup's Avatar
i feel like it should be more than 410 now tho i wonder if something is restricting it.
Old Apr 24, 2009 | 03:11 PM
goober35's Avatar
My first thought was that you seam to be missing some power. Could you be running out of injector. What do you have done to the fuel system. Stock?
Old Apr 24, 2009 | 07:47 PM
fatdave's Avatar
Im running the MS4 with fully ported 241's, ARH, Harland Sharps, Fast90, Nw90, March Underdrive...... Put down 430 RWHP on a mustang dyno
Old Apr 24, 2009 | 10:16 PM
teke184's Avatar
gotta remember, heads can make or break the deal.
they may look nice, but flow for ****.
while it seems a bit low, its a dyno....they are all different.
i was surprised i only hit 390rwhp up from 382rwhp when the cam went in.....upgrades included true duals, roller rockers, light flywheel, EWP, and correcting an issue with the TB blade only opening 85%
while some of that i attribute to going from 245 tires to 315s....and a different dyno...i was a little disappointed.
but for all i know it would have done +10 on some other shops dyno...which is what i was anticipating.
but i was happy with the 18hp i gained peak, and 5-10hp across the rpm band i gained with the ported FAST...on stock heads.
Old Apr 24, 2009 | 10:34 PM
1SLwLS1's Avatar
This will be my setup, did you go with the standard 111LSA?
which heads are you referring to?
Old Apr 24, 2009 | 10:44 PM
litemup's Avatar
its the new 215cc prcs, and the fuel system is stock but it didnt lean out at all he never said what duty cycle they were, my k&n was pretty dirty i wonder if that has anything to do with it, i think when i go back i will take my air filter out.
Old Apr 24, 2009 | 10:46 PM
1SLwLS1's Avatar
I would think the TB not opening all the way would have a bit to do with it
Old Apr 24, 2009 | 11:57 PM
joker machine's Avatar
With that big of a cam you need bigger injectors.
