Fuel Milage ???
Old May 19, 2009 | 12:55 AM
Nitroused383's Avatar
Originally Posted by TORCHD 02 TA
I have a 228/232 cam in my M6 Trans Am....
When i had my stock 28# injectors babying it on the street i got about 15-16 mpg. On the hwy in 6th gear i got 26 mpg. Now again with my stock 28# injectors my duty cycle was 99%.. Meaning they were spraying ALL THE TIME...... And to a tank of gas i would get about 175 miles to a tank..
Now fast forward to beginning of May. I installed my 42# injectors. I forgot to mention my car is not a DD. But i have not even gone thru a tank of gas but my needle does not move as fast. My duty cycel is now 56% and right now i am almost at a 1/2 tank and i have driven 145 miles. Soo umm yeah you can see i am doing ok. I am hoping to see over 200 with this tank. Somthing i have not seen since i was stock or not driving on the hwy
mods and numbers are in sig
You're injectors are always spraying all the time unless you are under DFCO. 99% duty cycle means you were maxing out the fuel flow of your injectors at high rpm. You may see better mileage by having a set of flow matched injectors but really you cannot judge your mileage by how far your needle is moving. Fill the tank, reset the trip odometer and drive it until you need fuel. Divide your trip odometer reading by the amount of gallons it takes to fill it up. If you are getting less than 200 miles on a tank you are getting under 13mpg.
Old May 19, 2009 | 07:04 AM
topher455's Avatar
Originally Posted by novaflash2002
with my 04 gto with a a4 auto i get 19.5-22 mpg in town. (thats calc by hand not the one in my gauge cluster). on the hwy i rarly go under 85 mph and i still get 26 with an auto.
What mods are done to your goat?
